Results 1 to 5 of 5
Thread: WTB/lend: Injection solenoid resistor map 4agze *Urgent*
    Senior Member n00bvak's Avatar
    Novak
    SOR
    Default WTB/lend: Injection solenoid resistor map 4agze *Urgent*
    Hey Guys,
    Missing a solenoid resistor pack for my ze conversion, looks like I may have left it in the half cut that has been sent to car heaven. Its the only part stopping me from starting my engine and need to get my hands on one ASAP.
    I have Toyota chasing one down in jap land (if there are any) which could take a while. I also do not want to hack up my loom to put in individual resistors per injector as I will be running aftermarket ECU which apparently does this itself. I just need to have the car running before I take it down there.
    Also does anyone know of any other Toyotas that use the same resistor pack so I can scrounge wreckers, that would be good too!
    I'm in Perth SOR so if you can lend me one form there 'unfinished project, for a weekend or two that would be awesome.
    Details:
    Request - injector solenoid resistor pack
    Engine : ae92 map 4agze (or compatible)
    Pics : below (stolen from toymods)
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
    Veteran Nikkojoe's Avatar
    Tom
    Ads should have one.
    AE82 redtop bigport, ae92 redtop bigport, ae92 smallport and ae92 bigport gze will also work. AW11 models may run them aswell
    Also you can run without one, I did on my ae101 gze loom for ages. Just use a blade connectors and split the power for the injectors over the two wires.
    Novak
    SOR
    I'm guessing Ads is the one that works with trist at WTF?
    BTW cheers for the info
    Tom
    Yep. I remember him saying not long ago he had them.
    Novak
    SOR
    cheers Nikkojoe, Ads hooked me up and all sweet
    $20 = wiN
    japan has no more
    btw, 7M, 1G, 5M all use the same resistor and connector apparently for anyone else that needs one.
  1. WTB - 4AGZE Boost Pressure Solenoid
    By joelae86 in forum Cars or Parts Wanted
    Last Post: 25th February 2012, 05:04 PM
  2. Replies: 0
    Last Post: 8th December 2010, 06:21 PM
  3. using OEM resistor pack with adaptronic for 4agze injectors
    By slide86 in forum Technical - Questions
    Last Post: 14th October 2010, 11:44 PM
  4. WTB .. Map Sensor for 4AGZE (out of AE101) Supercharged
    By esjay in forum Cars or Parts Wanted
    Last Post: 11th March 2009, 06:24 PM
  5. WTB URGENT 4age map sensor
    By Andor in forum Cars or Parts Wanted
    Last Post: 10th September 2008, 08:03 PM
Tags for this Thread
