Results 1 to 7 of 7
Thread: Garrett Turbochargers
    Gone
    Joel
    Picton
    Default Garrett Turbochargers
    Product - Garrett TurboChargers
    Since 1954 Garrett's team of engineers continuously strive to bring the best technical product to the industry. Today Garrett's team of over 500 engineers are working worldwide to further enhance Garrett's ability to meet demanding engine needs.
    The Garrett Performance team is bringing Garrett’s turbocharging technology to you for use in your applications. The Garrett Performance Product Catalog incorporates the technology utilized in today’s modern engines.
    Aerodynamics:
    New compressor and turbine wheel blade designs have improved the overall efficiency of both sides of the turbocharger.
    The result: the engine spools up to boost quicker and reduces losses in the engine system (i.e. your engine does not have to work as hard for the same boost level).
    GT Product Line:
    The Garrett GT product line has expanded to include:
    Engines from less than one liter to 10 liters with a range from 50 Hp to 2000 Hp
    Increased thrust bearing capacity
    Part count reduction resulting in higher durability
    GT products use the latest aerodynamics
    Separate backplates allow the user to upgrade the compressor without changing the center housing
    Proven Performance:
    The Garrett Motorsports group boasts a winning record including:
    Team Audi and their LeMans Hat Trick
    Team Audi and the first undefeated diesel LeMans champion (R10)
    Top 3 positions in LeMans 6 years running
    127 of 196 Champ wins since 1993
    11 CART championships
    14 Indy 500 winners
    5 Pikes Peak International Hill Climb Overall Championships
    4 World Rally (WRC) Championships
    6 World Rally (WRC) Manufacturers Championships
    1st 200 mph Streetbike ¼ mile pass
    Garrett technology under the hood of every boosted NHRA Sport Compact champion 2005 & 2006
    Info:
    Contact me for all your garrett turbo and accessory needs.
    Turbos can be off the shelf items or custom made to your personal specs.
    Note: internal gated turbos that require a wastegate actuator are sold seperatly
    Price: POA - can look at matching genuine retail Quotes
    Gone
    Joel
    Picton
    the VF 39 are used factory for the USDM sti's from 04-06...and all the new EJ25 engines.
    ill have to see if garrett make a turbo with the right exhaust housing flange to mount it all up. ill look into it for you
    GT2871r are around $1650 and around $170 for the actuator
    Glenelg
    price on GT3076r?
    Nic
    Mt Evelyn
    price on gt2860rs with .64 rear housing. dont need an actuator as im using ex gate.
    nic
    Gone
    Joel
    Picton
    are you after 4 bolt rear housing or V band?
    also what A/R turbine housing are you after?
    Gone
    Joel
    Picton
    sorry for the slight delay guys.
    Prices as follows
    GT2871R - $1690
    GT3076R - $1820
    GT2860rs - $1550
    Gone
    Joel
    Picton
    Garrett do a 3071r bolt on for the subie - $1850
    you can also get a Perrin 3" intake kit to go with for $450
  1. sr20det motor with garrett 2871r
    By turn69up in forum Car Parts For Sale
    Last Post: 6th December 2011, 06:02 PM
  2. sr20det manifold and t28 garrett turbo
    By fatke in forum Car Parts For Sale
    Last Post: 16th February 2009, 10:43 PM
  3. Garrett GT28RS Disco Potato
    By 70XIN in forum Car Parts For Sale
    Last Post: 14th September 2007, 01:05 PM
  4. FS or SWAP Garrett GT3040R turbocharger
    By d-shiznit in forum Car Parts For Sale
    Last Post: 24th May 2007, 03:20 PM
