motor bike shops can help you out with that one, got mine custom made at motor bike shop.
just take your throttle cable to the shop they will be able to shorten it for you.
Car - ADM AE86
motor - 4ac
use - daily pig
problem - just installed Weber 32/36, and now the throttle cable is to long
occurs/started when - now!
personal situation - need a shorter one, what other car's throttles can i use? or where can i get a shorter one?
I went to a motorbike shop, and they can't shorten the cable and housing.
went to a cycle shop, they couldn't either.
need to get it done by monday.
is there anywhere in sydney that someone has got this done.
or is there keXX that is around 80mm shorter?
cheers mate, had a feeling it might of been the case (after google searching "throttle cable", and mainly bike pages came up.
Go to a push bike shop, get an odessey linear slick.
Cut to correct length.
Make plates and adjusters on either end yourself.
thats another idea, cheers
went to cycle and motorbike shop, and they can't shorten my throttle cable.
has anyone got it done before?
AE86....robbing me! check the build.
http://www.ae86drivingclub.com.au/fo...read.php?t=445
the bike stores dont sell shorter ones?..
dose
Try a different bike shop. That's just crap, sounds like they're lazy.
ive never had an issue runnin a long cable looped round!!
AE86 THE BEST
^^ agreed. just put a clip on the strut tower or somehwere so it is tight enough to work.
