ive drifted in a 20v NA with 16's with 3.3 diff gears.
wasn't that hard.
give it a go and tell us how it goes with the 15's
hey guys .
getting my car back pretty soon ... got my licence back and now being on the new stupid p-plate laws means that i cant drive my 4agte sprinter ... anyways in the next week or so .. it will a na 4age .
just wondering if anybody has drifted on 15inch rims ... ive done it in my sprinter when it was turbo'ed but how hard will i need to work the car to get it spinning on a smallport 4age???
more speed and balls .... me thinks
wasn't that hard.
Was your 4agte a gze turbo or did you start with an n/a smallport?
i slide my na big port on 15's all day every day no issuse i think max front grip is the key other wise under steer+.....
if u struggle just pic up few second hand low grip rubbes prac on some and leave the other out to dry out for few weeks and you'll be away no worries![]()
second to a hammer a cable tie can fix anything!!!!
fairly sure it will be the same as it is here in QLD.
if you lose it while on your P's but you had your P's before the new laws,
when you get it back again you count as if you only just got your P's i.e all/most of the restrictions/curfues now apply.
OP: "more speed and balls" - spot on!
im new to drift but as such would it not be the same as driving on some 13 or 14 ??
the smaller the wheel radius the easier to spin, ie putting 17' on a ke70 stock would NEVER HAPPEN!!!
i have 15' on my ke70 with a board out 4k and it slides in the dry alright
~KEEP DRIFTING FUN~
yea but rolling diameter of 13 14 15 are all pretty much the same so he should be fine ill be drifting my 4k on 13 14 15 i have all 3 sizes to use ill c what i find best
