Results 11 to 20 of 24
Thread: Slow cranking speed on 3sge
  1. #11
    Veteran biggo's Avatar
    Nick
    Noosa
    i did everything, pulled plugs out, disconnected the ecu etc etc.
    Without spark plugs it does about one crank rev a sec
    I even pulled the started apart and cleaned all the contact surfaces. Its on the long side of old now tho. Might have to buy a new one.
  2. #12
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    It really does sound like the starter is dead tbh.
  3. #13
    Veteran driftke70's Avatar
    Ryan
    Buderim
    he didnt go out with a bang though
    wheelfriends.wordpress.com
  4. #14
    Nick
    Noosa
    starter turns out to be fine. Still has plenty of balls.
    Im now going to hunt thru some wires. Me thinks there to much current draw and nead more earth. + terminal still gets bloody hot tho.
  5. #15
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the terminal is not meant to get hot..
    how did you test the starter?
    its not a dud battery?
  6. #16
    Nick
    Noosa
    Put it in a vice and got a jump pack on it. Then proceeded to 'load' it up with a peice of wood hehehe
    Yair theres a short somewhere in the body loom. Going to have to pull it all apart again and find it.
    Ghey
  7. #17
    Ryan
    Buderim
    if i had my license id head round and help ya,
    sounds like the starter feed isnt heavy enough guage, and the the earth isnt great. Its obviously there otherwise it wouldnt crank, but alloy bells dont have the greatest earthing properties.
  8. #18
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    got enough earths to the engine???
    earth a wire straight of the bellhousing bolt holding the starter on
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
  9. #19
    Nick
    Noosa
    Thats the plan, theres still a short on the body loom which is causing alot of current draw.
    It works fine if i remove the car from the starter circuit tho.
  10. #20
    Endeavour Hills
    make up a whole new starter loom and have it seperate from the body/ecu loom, thats what I did. Let me know if you need anything made up.
  1. VIC Beams 3sge duel vvti with 6 speed
    By random user in forum Car Parts For Sale
    Last Post: 16th December 2012, 02:25 PM
  2. 3SGE 6 speed clutch slave....
    By Touge Boy in forum Technical - Questions
    Last Post: 7th October 2010, 07:39 PM
  3. os giken super single clutch to suit beams 3sge with 6 speed
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 2nd August 2010, 05:32 PM
  4. 3sge 6 speed
    By fantapants in forum Technical - Questions
    Last Post: 15th April 2009, 10:13 PM
