Results 1 to 10 of 19
Thread: PIC REQUEST - 4age engine bay shots
    Jon
    Durack
    Default PIC REQUEST - 4age engine bay shots
    show me what you got
    Sherlock
    Last one isn't a 4AGE obviously but they're still good inspiration...
    Jon
    Durack
    good stuff im trying to figure out what i should be doing with my oil catch can(location and where to run the hoses)
    E-Famous (Remeber your roots)
    Veteran shift_rook's Avatar
    SE Burbs
    may aswell close the thread, thanks marvis haha
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    My fave
    Simple, Functional, Clean
    About the only cool thing about USDM cars is the brake booster location
    Jon
    Durack
    Marvis thank you!
    Jon
    Durack
    someone explain what this is/does
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    It's just a breather hose thing. Basically excess oil from the head goes through that hose and into the intake manifold to be burnt off.
    Site Supporter Javal's Avatar
    Josho
    Close.
    It's a Positive Crankcase Ventilation hose (PCV). It vents gasses introduced into the crankcase via slip past the piston rings + a few other places. These gasses often pick up a bit of oil on the way out. The pipe plumbs back into the intake tract so the gas / oil mix is burnt, not put straight into the atmosphere.
    You correctly described the basic operation, sort of.
  1. Engine Parts & Engine Bay Stuff
    By 44GTE in forum Just JDM Imports
    Last Post: 6th June 2009, 10:35 PM
  2. Pic Request:Best looking 4age Engine
    By haydenzz in forum Toyotas in the Media
    Last Post: 1st April 2008, 08:27 PM
  3. Post a Pic of your engine bay!
    By marvis in forum Toyotas in the Media
    Last Post: 28th June 2006, 09:05 PM
