Now because I had some free time today with very little on my to-do list, I decided to take a look inside that 18R-GEU I blew up and see how exactly how badly I killed it.
Cam cover off. Black oil. Carbon contamination? My best guess is poor ring sealing coupled with an over-rich mixture.
Sump off. Bad
Bad bad not good.
Rod ends off. This is #3. Whoever put this motor together didn't really pay attention to cleaning it seems.
It's been run dry and had the absolute piss hammered out of it.
#2 had left a surprise, probably from also having the absolute piss hammered out of it.
Then in a shocking turn of events, #4 was relatively happy. I was expecting to see carnage.
Fabulous. I've managed to turn my bearings into glitter.
I was kind of expecting worse. Like bearings welded to crank worse. Everything should come up OK, the crank and rods may need to be re-sized but they appear re-usable.
After blowing way too much money on the motor i'm going to take a slightly lower budget approach to things for a while. I reckon next little project will be identifying exactly what kind of gearbox this is, whether it's a W55/56/57/58. Pretty sure it's a 55, it's definitely got an R-motor pattern bellhousing on it. Might rebuild it with one of the apprentices at work or something.
That's all for now.
