Anyone know the lengths of MR2 SW20 rear shocks for use as AE86 front shocks?
Just go with the Holden wagon Excel G rear, 343113 part number, is stiff enough for 4kg for sure, i found it to be a good combo.
^ found this in another thread
what model holden wagon kona kid??
VB-VR rear wagon shocks
Thanks Dylan, looks like they'll do the trick then.
sorry if it has allready been said but i couldn;t find it ...
what shock will bolt into the 'Front of a ke70 ? mine a rooted
nothing worth buying, you need to change to an ae86 or t18 strut as its 2inch which gives you many more shock options.
ah ok .... does this mean strut... brakes.... and what ever else?
yeah you'll need the 86 struts, brakes, brake lines, and ae86 steering arms.
Costs a bit but allows you to run Roll centre adjusters, huge range of performance shocks (TRD, Bilstein, Tokico, KYB) and springs are easier to come by, or you could turn them into coilovers.
Also gives you access to JDM vented brake rotors + calipers, and much larger range of proper performance brake pads in the ae86 size.
