Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 38
Thread: 20V Conversion AE86
  1. #21
    May 2010
    Derryl
    CA
    Napa Valley
    United States
    You can use the factory blacktop ecu with COPs. Theres a thread on club4ag about this, I've had my silvertop on blacktop electronics for almost a year daily driven atleast 30 miles. Diagram courtsy of VitriumGTS
    Link to original post
    --SAMS EDIT--
    Link to a guide on 86 garage that I think is much easier to follow:
  2. #22
    gawler area.
    has any one wired the standard loom too the ae86 body loom im going to do this conversion and im going too using the loom and ecu that comes with the 20v just need too know what too wire up too the body loom.
    hachi roku
  3. #23
    Moderator Sam-Q's Avatar
    Endeavour Hills
    hey it's under the wiring section of the technical index:
    called: "Wiring diamgram of the large plastic plug on the firewall of an AE86"
  4. #24
    Member lanky101's Avatar
    Brendon
    Reservior
    chur boy's. found a bit of a gold mine at work today, got a set of coil packs and connectors that fit perfectly into b/t 20v s'plug tubes, no filing req, perfect height, only thing is they are off a Belntly Continental GT.... 4 pin, 2x earth, 1x 12v power supply and 1x signal. i doubt anyone will take this seriously, because, honestly, who's going to try and find 'em, but i'll do a bit of research and see if they are common with anything else. just thought i would put it out there. pics up soon.
    brendo.
    Ohh, B/T 20v, How I Want To Hear You Scream!
  5. #25
    Endeavour Hills
    wow that's bizarre, yes post any extra information you have for sure ok?
  6. #26
    Brendon
    Reservior
    more than likley, they will be the same as some V.W cars, (as V.W owns bentley...) ill dig.
  7. #27
    Senior Member billett86's Avatar
    Mar 2010
    Toby
    Adelaide Hills
    has anyone in S.A done this conversion and can you get it registered in a ke70?
  8. #28
    Veteran Kid Karola's Avatar
    Karl
    S.A.
    Austria
    Interesting.. very interstings. Are they from the 6.0 W12 or the 4.0 V8??
    If you think about it splitting cost 2-3 ways for a set could be reasonable.
    As you said likely common part with VW/Audi that runs similar engine (S/RS range)
  9. #29
    Brendon
    Reservior
    I got about 30 of em at home now, they are outa the W12... I found that if you use the 'sam Q coil pack mount coupled with the s/plug lead seals off a 1.8 '05 corolla , they are nice and snug. I'll post some pics once I've wired them up into my car
  10. #30
    Endeavour Hills
    I am interested to see how they fit, are they are 2 or 4 pin coil?
  1. Replies: 5
    Last Post: 19th June 2010, 04:07 PM
  2. 20v conversion
    By corknose in forum Technical - Questions
    Last Post: 19th July 2009, 02:23 PM
  3. 20v conversion in ae86
    By deanoo in forum Technical - Questions
    Last Post: 9th June 2009, 09:42 AM
  4. 4ac to 20v conversion in a ae86
    By 1sik20valve in forum Technical - Questions
    Last Post: 23rd April 2009, 05:51 PM
  5. 20v ST Conversion into AE86
    By Dan_AE86 in forum Technical - Questions
    Last Post: 2nd July 2007, 07:41 PM
