Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 38 of 38
Thread: 20V Conversion AE86
  1. #31
    Member lanky101's Avatar
    Brendon
    Reservior
    4 pin, 2x earth, 1x 12v power supply and 1x signal
    Ohh, B/T 20v, How I Want To Hear You Scream!
  2. #32
    Moderator Sam-Q's Avatar
    Endeavour Hills
    so they also have built in ignitors which is excellent. Please post a pic sometime
  3. #33
    Senior Member Dfectd_Drftr's Avatar
    Jamie
    Mudgeeraba
    I will be honest... I found the 20v conversion very simple, seems like some people make it out to be harder than it actually is! I purchased my water kit, spigot bearing etc from SAMQ here on the forums. He was very helpful and the kit works well. There are a few fluctuations in water pressure from standard, however I was to expect this when doing such a conversion.
    As for a thermostat, I had a funky idea on how to make a housing actually look good! I purchased 2x 32mm V8 thermostat housings from a small block Chevrolet. By placing a thermostat in between the two, bolting them together and mounting them to the block, this makes for an effective, easy to maintain pressure system. It will not work if you require a heater, but on my 86 makes my engine bay just the little bit cleaner!
    Also, I just cut a hole in my firewall, makes up for the lack of heater I will fix up the hole when winter and early morning driving is over!
    Current Track Hack - Nissan 180sx
    Job - Full Time Mechanic ... Hobby - Helping Fozz
    オーストラリアの独立ドリフト学会
    mx_jay_862@hotmail.com
  4. #34
    Endeavour Hills
    thanks! although don't talk to me about holes in firewalls!
    Things are likely to get even simpler soon, if things work out the way I expect then there should be two new distinctly different options of rear wheel drive compatiable air boxes, neither being made from my workshop unfortunetly but still. Also a Yager replacement pipe is in the works seeing they are no longer available.
  5. #35
    Senior Member dtour's Avatar
    Jun 2009
    Jon
    Ryde
    Do tell about these two options...
  6. #36
    Ok
    Seamus
    Milton
    ^2nd'd
    ^ Clicky clicky!
  7. #37
    Endeavour Hills
    I think there are 4 air-boxes available or going to be available for a 20V- Nobby Booth, Plasmaman, GTiR adaption and another one which I need to post a picture of.
    The GTiR intake adaption has a thread on here about the progress of it, and the last one is about a manifold I can source and then modify myself to suit rear wheel drive. I doubt it will be worth my time though as it would cost in the region of $580. Well regardless I will get a picture up
  8. #38
    Endeavour Hills
    I will shortly have a new water outlet available with a built in thermostat that should look really good. I will be an improvment of the Yager design which is no longer available as of a year ago. Is anyone interested in doing a test fit of one?
  1. Replies: 5
    Last Post: 19th June 2010, 04:07 PM
  2. 20v conversion
    By corknose in forum Technical - Questions
    Last Post: 19th July 2009, 02:23 PM
  3. 20v conversion in ae86
    By deanoo in forum Technical - Questions
    Last Post: 9th June 2009, 09:42 AM
  4. 4ac to 20v conversion in a ae86
    By 1sik20valve in forum Technical - Questions
    Last Post: 23rd April 2009, 05:51 PM
  5. 20v ST Conversion into AE86
    By Dan_AE86 in forum Technical - Questions
    Last Post: 2nd July 2007, 07:41 PM
