lca's sold pending payment
hey all
moral of the story is i brought an sr20 and need some money to finish the conversion!
i am open to swaps for the following....
sr20 computer
z32afm
r31/pintara diff
bosch 044 fuel pump
rb20/30 gear box
first up i have an 18rg out of my ke70 track car
seized!... it did it on idle so no domage was done to the head
recond head- probly done less then 100k's
twin 40mm mikuni carbs
trumpets..(1 i s a bit farked)
re-cond radiator
extractors
2 inch under diff exhaust track spek (loud)
has a w50 but is getting cruchy
w-t tail shaft
can include a wagon diff if it is going in a wagon
this motor has a mid mount sump so sits a bit further forward than most motors so the cross member needs some small modifications...
may part out if interest is there.
$500
second is my defected ke70 i brought to fix up and use as a daily
4k-4speed
fixed some of the rust
primered most of the car so its white and primer with a black bonnet
has cut springs and locker
has a 3inch single flute
has a couple dodgies!
dus not include wheels
basically i got pulled over b4 i could put different springs in
got done for to low to loud and a missing parker
(can supply things to get this of defect
$550
xt130 control arms
quite good bushes and ball joints
$80o.n.o
may have forgot some things
barossa valley s.a
pm me on here
more to come....
ke70 sold pending payment
bad luck with the engine on saturday bro. get the sr crankin.
interested in seperating the carbs and manifold off the 18rg. possible excahnge for efi setup?
If this doesn't go ahead, i have a few 18rg carbs and manifolds... am interested in 18RG efi stuff (not sure if that is the efi setup you mean?).
did you wind up sellin the rolla?
on another note i was wondering why your car was back on the
trailer so quick.
just one other thing those rear guards onthe rolla looked wider?
do you know what had been done to them?
