i rode a ruckus in texas, pretty awesome
these are pretty cool! So are they basically the same as the Zuma but with the 100cc? Might be an alternative if the Ruckus still never comes here, but im sure by then i'll just get a normal bike
wheelfriends.wordpress.com
Updates-i got some new bits
Malossi Variator
Carbon fibre front fender
Carbon fibre airscoop
Gianelli Exhaust
Sports Mirrors
And just waiting on a malossi sports clutch
Will have some better pics up soon!
does it do skids?
in the rain yeah
my mate has a 50 bored out to 80cc
it has heaps of torque down low but doesnt like to revv
Item : SPRINTER
+10 to agility
+30 commodore resistance
90% chance cast skid (while cornering)
did he rematch the opening times of the ports?
And the pipe, the pipe may be tuned for lower rpm.
Mine is 70cc, was 50cc. Bigger ports, better pipe, threw the cylinder in the lathe and decked it to tighten the squish (was over 40 thou squish clearance, now 22 thou). Stock carby was 12mm, that's gone in favour of a 19mm job. Advanced the ignition just a touch to beef up the bottom end.
Does 115km/h (and boogies getting there) by the gps on a flat grade without slip streaming, did 70km/h stock.
Next step will be porting of the cylinder and port matching the casings.
what I mean is that if cylinder is bored on a 2 stroke the angle at which the ports open change, so by rights they should be corrected with a degree wheel
You mean because the ports are not of a uniformed cross section I assume.
Can also bore them on an angle (very slight) which has a crank offsetting effect...... or shift the cylinder fore/aft.
These also have an effect on port timing.
