got an oil cooler today.
also has provision for senders so can run some gauges
Sickest
haha i am on a mission
went to make gearbox mount again, and the bit of metal was too fuckin short haha
so tommrow ill go and get metal for that, exhaust twin pipes, new caster rod setup and yea.
Sickest
sweet what kind? i need one with gauge outlets
got it off a mate,
gave him a 100 bucks and a power steer pump. and he gave me his oil cooler. lol
its china, but willl do the job.
I know the ones being sold through ADM (forums sponser) have pickups for the gauges.
OMG OMG OMG, just saw this, so hot!!!!
Very well done sir, you are the man!
hey man.
have you put your car on the ground yet to check lock? i got the same set up as you now (thanks for the tip) and had a look at it in the air, the bolt on the bottom holding the steering arm/RCA into the strut clash's with the top of the castor rod.
i put some wheels on and droped it on the ground and it doesnt seam as bad, dont have tie rods/rack ends in either yet but best idea might be to weld a mount on the side of the lca to avoid it clashing altogeather maybe.
yea mate i know where your coming from..
i still have to modify my caster rods to make them adjustable (hopefully this weekend, bought steel yesterday.
i was going to make that up and give it a wheel alignment or close enough to and then go from there. so that i dont weld in the incorrect place. but yea i was thinking the same thing. but also was thinking of welding into the other side of the LCA to prevent the steering arm traveling any further, and then i wont have the issue with it getting jammed.
ill let u know how i go. or if u make it first hit us up
and grant, ill grab that wheel tonight mate, bring the ke around if ur keen
got tailshaft done, $160 so was stoaked with that!
also got 185/60 RE001s for $100 each.
IC piping is getting beaded.
Motor comes out sunday ready for block tappage. then all back in ready for wiring.
cant wait to see this finished , are you putting the 14x8 from ajps on this beast?
yea will have the 14x8-10 all around. and mesh for extra wheels. will be cool having 4 matching new wheels, well for me atleast
eventually ill use the superlites upfront and run a 215/45 semi on it. but for now they will do the job.
better not rain this weekend, so much planned
