Page 19 of 26 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 181 to 190 of 253
Thread: custom steering Knuckles and getting max lock
  1. #181
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    and the fact your tierod is hitting LCA, notch it
  2. #182
    Jason
    Gold Coast
    Blair, my first 86 setup was exactly the same as yours, actually my current 86 is as well now that I think about it.
    My first 86 started stock as thy rock. Then I added Corona LCA's and would run out of lock when drifting, then added PS arms and found at first I would hardly ever run out of lock, then when pushing limits would feel it hit full lock (like in your picture it would physically stop). I like that feeling cos there is none of that crazy wheel wobble you see in some datto's at full lock.
    My setup looks the same as yours (hitting LCA as well), and I too have trimmed front bumper. I think if it feels ok drifting, run with it, then down the track try some ackerman correcting arms, thats my plan anyway.
  3. #183
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Hey, I too have noticed the same problem in my ae71, I'm running 86 struts with standard ae71 LCA, but with t3 ps arms at the shorter hole.. My full lock is about 1.3 turns from centre both ways I thinkk. But my tie rods also hit my LCAs.. I have a fairly huge lock with just the ps arms.. and my 15x8-4 with 195/50 scrub my inner guard some times.. I get a slight scrubbing on the rear of my front wheel arch too, from the tyre turning outward from the car.. but I think this is due to the lack of castor im running (only like 2.5 even on both sides).
    But yes, I too get the tie rod to LCA rubbing lol..
  4. #184
    E-Famous (Remeber your roots)
    I call that the nissan dance!
  5. #185
    Veteran blair's Avatar
    Blair
    SEQ
    Finally some real fucking answers! cheers lads. i'll just rock it for now then
  6. #186
    Junior Member Slidin' 71's Avatar
    Leigh
    ^^^That's if you want to waste a shitload of money.
    Or Blair, you could just get some quality cut n shut knuckles (under $100, or else you're getting ripped blind) and it will solve all the problems you are having as the ackerman correction will move the tie rod end further away from the control arm on lock.
  7. #187
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    some times its a little better to pay a bit more to get someone who knows there shit, then a 17yr old who "can" weld
    ~KEEP DRIFTING FUN~
  8. #188
    Veteran KurtHS's Avatar
    Kurt
    East Melb
    Leigh's probably referring to JDI Fabrications knuckles, can't fault anything on them, dudes a shithot fabricator.
  9. #189
    Leigh
    Lol, if people are fine with paying more than that for an hour or so labour than that's fine. But I would suggest to most people to do some research before paying for knuckles as some people are charging exorbitant amounts for the work they're getting, especially if there has been no r+d involved in designing them.
    And by the way, the only knuckles I know of under $100 are made by probably the most qualified welder/fabricator in the country that makes knuckles. If you're buying parts that have been modified like cut'n'shut knuckles it would be worthwhile finding out who has designed them and also who is fabricating them. As a failure with a part like this would have some disastrous consequences.
  10. #190
    May 2010
    Nick
    Ipswich
    should see his dance that goes with it.
  1. T3 Ae86 Extra lock Steering Knuckles
    By sundee in forum Spirited Drive
    Last Post: 20th March 2014, 07:02 PM
  2. Lock spacers and custom steering arms
    By trikzlane in forum Technical - Questions
    Last Post: 2nd September 2013, 07:25 PM
  3. T3 Ae86 Extra Lock Steering Knuckles
    By PRIMRK in forum Car Parts For Sale
    Last Post: 15th October 2011, 06:33 PM
  4. KE70/AE86 Custom lock Steering arms
    By trikzlane in forum Car Parts For Sale
    Last Post: 15th May 2011, 07:11 PM
  5. S13 custom shortened steering knuckles
    By FAST EDDIE in forum Car Parts For Sale
    Last Post: 10th December 2009, 07:55 PM
