Page 3 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 253
Thread: custom steering Knuckles and getting max lock
  1. #21
    Yes, See how a standard arm has like that bend in it, and where the tie rod is mounted is offset to the ball joint hole.
    When you are full lock, say.. doing a right hand corner, you are full lock to hte left. The outside wheel, which would be the passenger side will have most lock and hte inside wheel will not have as much. It will actually be dragging. So removing some of all of it, increases the inside wheel's lock.
    Speaking to a good friend in japan he recommends just removing ackerman from p/s arms and the extra lock you get on the inside wheel is enough
  2. #22
    Veteran bigm's Avatar
    Gold Coast
    im running T3 arms in my car. they are so short that the tie rod hits the LCA on the closest setting (90mm from balljoint)
    I put it onto power steering hole (115mm) and it gives me more clearance to the tierod/LCA but the steering arm is very very close to level with the rack arm...
    i duno how to go about moving the rack forward?
    how did u overcome it on your car Boost+k?
    and it is called binding when your steering arm and rack arm are at the same angle yea? you cant move at all?
    This is a pic with it on the inner most setting.
  3. #23
    Gold Coast
    yea thanks mate, i just wasn't sure where the measurements were taken from. ill measure my ones when i have them off next.
  4. #24
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Binding is when the ball joint the tie rod and the knuckle in the rack end are all inline..
    The pic of yours Bigm is not binding...
    Everyone on NS complains about binding with shortend knuckles in there s13's..
    My s13 knuckles are shortend and i don't have any issues with it binding up.. And s13 into 86 is sposed to be worse than in S13..???
    I've been waiting AGES for you to tell me how those knuckles went in your car Robo..
    Can't believe you forgot about them...
    I feel so neglected..
  5. #25
    Veteran Robo86's Avatar
    Rob
    hahaha, been busy man. put urs in but havnt put coils back in yet. The angle isnt 100% where the tie rod end bolts in. kinda doesnt wanna fit, but ill see!
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  6. #26
    Nic
    Mt Evelyn
    the JDI fabrication arms are, 10mm shorter than PS arms and 7mm off 0 ackerman.
    robo i will still get a pic over the weekend sometime
  7. #27
    Jason
    Nundah
    I was wondering if that might be a problem Rob...
    I made them flat without the twist that the factory puts in them.. Its much easier to make the jig if you do them like that.. Plus they're only a prototype.. No biggy if they're quite right..
    I noticed that a few of the aftermarket machined arms are flat so I figured it would still be alright..
  8. #28
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Cant coment too much on this but Ive just replaced my standard knuckles with the T3 items due to one being bent... I'm not/wasn't really looking for an increase in lock, just a stronger alternative.
    The T3 knuckles are fuckin beefy as, solid steel around 15+ mm thick. I have them on the outer setting and my 15x8's 0 offset rims (195/50s) touch the inner guard wall on full lock, the other issue Ive encounted is on full lock the bottom of the arm hits (slightly) the top of the stock castor arm where it mounts to the LCA, but I think this is due to having xt130 arms....
    This could probably be easily fixed by grinding a small amount from that area on the arm......
    Haven't driven it yet apart from a lap down the street at no more than 15kms so cant really provide much more feedback other than the steering was pretty heavy but very direct (I have a quaife rack also)
    BENT MECHANIX - Garage 20:
  9. #29
    There shouldn't be a problem fitting them unless the tie rod hole ID has changed. Just move the tie rod end bit around to fit in. My Garage Clear ones are flat.
  10. #30
    hey man products still retain the twist
  1. T3 Ae86 Extra lock Steering Knuckles
    By sundee in forum Spirited Drive
    Last Post: 20th March 2014, 07:02 PM
  2. Lock spacers and custom steering arms
    By trikzlane in forum Technical - Questions
    Last Post: 2nd September 2013, 07:25 PM
  3. T3 Ae86 Extra Lock Steering Knuckles
    By PRIMRK in forum Car Parts For Sale
    Last Post: 15th October 2011, 06:33 PM
  4. KE70/AE86 Custom lock Steering arms
    By trikzlane in forum Car Parts For Sale
    Last Post: 15th May 2011, 07:11 PM
  5. S13 custom shortened steering knuckles
    By FAST EDDIE in forum Car Parts For Sale
    Last Post: 10th December 2009, 07:55 PM
