Page 5 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 253
Thread: custom steering Knuckles and getting max lock
  1. #41
    Gone
    Joel
    Picton
    each to their own.
  2. #42
    Senior Member Intense's Avatar
    Aaron
    Guys, I've just got a stock adm rack with aussie steering arms, running 195/50/15's on 8" rims and on full lock my wheels already grind away at the inside of the guard, so much so that it looks like polished metal. So if I got p/s arms wouldn't that make the problem even worse? How do you all run so much lock without this problem, the only way I can think to fix this is to run spacers on the front or increase the front track with lower offset rims.
  3. #43
    Gone
    Joel
    Picton
    Getting PS arms will just give u more lock, so it will just jam the wheel into the inner guard even harder
    What offset are the wheels?
    increasing the track , with wheel offset or longer LCA's is your answer, or a slip on spacer for quick fix . dont quote me on this but i thin for 8's up front u need atleast a Zero offset to get clearance.
  4. #44
    Aaron
    I've got 8" front with -4 offset. Going to get bolt on guards and +25mm bolt on spacers all round so that should solve the problem
  5. #45
    Veteran corknose's Avatar
    Callum
    i think even my 14x8 -12 still rub
  6. #46
    Todd
    Auckland
    Auckland
    New Zealand
    dom86 : heres a pic but i dont have a referance pic of a factory one to compare to
    intense :you need longer lower arms for big lock potential... i run 195-45's at the track for more clearance also, you should get away with ke30 lower arms with manual steer arms, there about 10mm longer, are you running camber plates aswell?
  7. #47
    Aaron
    Yeah already got camber plates maxed out, cusco ones that only max out at -1.5 degrees. Planning to go bc coilovers later on so I should be able to get more camber out of those. If I were to go a different set of lca's I'd probably use corona ones because they're easy to come by.
  8. #48
    Callum
    youll want to set it max posative to stop rubbing if u think about it, its pulling in closer at the top.
  9. #49
    Ken
    Spearwood
    Just cause the Garage clear arms have lumpy welds doesn't mean their any dodgier than any other cut/shut arms. If it's welded, it's welded, if you get paranoid grind it smooth.
    Been running Hey-man arms for awhile now. Cut and shut arms lock aren't any greater than powersteering arms, the difference is of course ackerman, since both wheels are pointed towards the way your steering instead of one giving more drag, therefore, whilst sliding you will feel less front scrub and actually be able to carry more speed through your entries and mid slides. The difference in lock is that you'll get to max lock faster and have quicker steering.
    Someone mentioned about how you stop scrubbing on your wheel walls and how you would get anymore lock. You need more castor and more track, then it won't scrape.
    For track use, shortened and 0 ackerman knuckles are great, even for street it's awesome, but you can definitely live without it. Work on other aspects of suspension/chassis before this, it's one of those things where, unless your getting real technical and your car can match your driving skill, you won't really notice it. Example, if your still arse dragging and doing weak entries, it's just silly.
  10. #50
    Todd
    Auckland
    Auckland
    New Zealand
    Intense : your camber plates won't be helping... better to go for longer lower arms and set the camber plates further out to get clearance
    IMO camber plates are not for gaining camber they are only there for tuning the setup/ getting even settings, i always run longer arms to gain the camber i want...
    just remember that any track you gain in the front you should also add to the rear to keep things balanced
    yea corona/ke30 arms same thing so all good
    what ae86hachiroku said is dead right, drive your setup to its limits then start doing things like this to get faster/smoother
  1. T3 Ae86 Extra lock Steering Knuckles
    By sundee in forum Spirited Drive
    Last Post: 20th March 2014, 07:02 PM
  2. Lock spacers and custom steering arms
    By trikzlane in forum Technical - Questions
    Last Post: 2nd September 2013, 07:25 PM
  3. T3 Ae86 Extra Lock Steering Knuckles
    By PRIMRK in forum Car Parts For Sale
    Last Post: 15th October 2011, 06:33 PM
  4. KE70/AE86 Custom lock Steering arms
    By trikzlane in forum Car Parts For Sale
    Last Post: 15th May 2011, 07:11 PM
  5. S13 custom shortened steering knuckles
    By FAST EDDIE in forum Car Parts For Sale
    Last Post: 10th December 2009, 07:55 PM
