Ok latest update, fitted up some whiteline bars, surge tank, lift pump, boost controller and a heap of other stuff. Took it in for a tune yesterday and it did 120rwkw. Drives pretty well, plenty of get up and go. The only thing that I am a little worried about is that at 3000rpm it is only making 6psi and taking until 4500rpm to make 12psi. This is with a t25 so it seems to be taking a long time. I would have though it should be boosting from around 2500 and all in by 3500, 4000rpm at the latest. I even tried to disconnect the wastegate to see what the best ramp rate was but it wouldn't do better than that. I hope that it is just a small leak some where but I will need to get a boost guage to see the difference between the turbo and inlet.
Paul
