in the end of your drive cups, try running some orings that fit nice and snug, from memory shock seals work well. Also check for slop in the steering parts, and bearings. If its all a bit loose, replace it, plastic bits are cheap.
cos im too tightass to buy batteries and tires lol and sort out the front end
But it's as if it has too much lock. Like on full lock the dogbones aren't captive. I am gonna get some stock arms and see if that helps.
i had to cut down the foam pad on the front of mine as on lock my wheels were fouling it, and mines all stock, but dogbones never come out???
it needs the orings. They even say it in the manuals.
I should explain what is happening.
You have play in the dogbone, now with out the orings, when you go to lock, the dogbone has enough play to slide to one side, then as the drive cup rotates, it reaches a point, where one of the lugs on the dogbones comes out of its slot, as it rotates works its way out, and there you go. Its quite simple, and it will only cost you a dollar.
DATE:28th of FEB
TIME:2PM - ON
WHERE:Monash Clayton rear Carpark (outdoors if nice day Undercover if not)
Comp Cost: Gold coin or NOTE
Prize for winner: 1st 40% of donations, 2nd 30% of Donations, 3rd 20% 4th 10% (YES CASH PRIZE BITCHS)
Track will be a tight track so this way brushless and sportstuned can both be good
ABS Tyres a must
And come to the Friday night meet for practice i prob will not be there but if all goes to plan the thursday night i will mark out a track my self as friday i have soundwave and saturday i pick up the new car that i will prob pick up dharvs in if he reads this and pms me about it
I thought i would post it here for now i cbf posting it melb section but yeah i use to run RCD1 back in melb and have been asked to start running evnets agian as the old owners after me fucked it all up so yeah here is a event if people want to post it on other forums cool cool
got a link to theese ABD tyres??? i use drift daddys
just seeing if anyone here would be interested in buying a TA03R chassis. Its the one i bought from here late last year. Carbon fiber top and bottom deck, rear sway bar, alloy servo mounts, aramid belt, different shocks/springs, 1way front diff. Will come with no electrics, batteries or wheels. I want to get something a little newer like a TA05. Looking around the $200 mark in Melb if anyone is interested.
Ill get pics and links etc later. If theres no interest ill keep it as a shelf queen and wait till tax time for the new one
