Page 11 of 16 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 101 to 110 of 151
Thread: Drift RC Cars
  1. #101
    Veteran slydar's Avatar
    Dimitri
    just get cvds. problem solved. if you buy them on ebay youll probably get them for less than $30 posted.
    78's
  2. #102
    dog bones falling out.....you should have this thing between the dogbone and the cup which is like an o-ring. hell an o-ring will do. usually sits on the diff side. from memory the hub side does not have it.
  3. #103
    Dimitri
    remember though most TT01s are all plastic, the plastic wears and then everything call fall out a lot easier. if you wanna keep your chassis youre probably better off getting some cvds.
    78's
  4. #104
    Stu
    Northern Suburbs
    Heres some pics of the TA03r
    the marks on the top carbon plate are from the double sided tape used on the ESC and transmittor. i tried cleaning it off but need some tea-tree or something to fully get rid of it. (i dont like chemicals) So it comes with alloy servo mounts and servo arm, turnbuckle top camber arms. I also noticed that there is a second position to move these to on the hub. You can have the allow wheel nuts too when i go buy a new wheel wrench to get the rims off.
    Spares include original diff, body arms, alloy motor mount, original battery hold-down, metal motor pulley and a heap of screws.
    Attached Thumbnails Attached Thumbnails spares..jpg   side on shot..jpg   underside..jpg   top shot..jpg   top shot 2..jpg
  5. #105
    Trung
    Keysborough
    Although abit dated, the TA-03 is a pretty dynamic chassis. You can have the motor mounted either at the front or rear, hell you can have a twin motored version.
  6. #106
    Stu
    Northern Suburbs
    yeah, TA03F, TA03R and the twin motor - The F + R utilize a slightly different gear casing but is available as conversion kits now. I just want to get something a little newer/less hardcore as im a retard/newbie at all of this stuff.
  7. #107
    Trung
    Keysborough
    TA05 is very good! I've had a TA03/04/05 and the 05 is good for the money. Alot of places stock parts and they are adjustable from the get-go. Good luck with it.
  8. #108
    Stu
    Northern Suburbs
    thanks man - hope the 03 sells quickly then i just need to hang out till tax time. Have my eye on a v2 with hop-up kit. I want belt drive otherwise id just get the TT01R kit
  9. #109
    Dimitri
    hey man i actually have a TB03D with some hop ups. its shaft but the yok' gears fit so youve got heaps of options for CS.. lemme know if youre keen on a trade/partial trade.
    78's
  10. #110
    Stu
    Northern Suburbs
    was that directed at me slydar? If so, what does CS mean???you have to remember im a newb so have no idea on terminology. Are you saying you can convert it to belt drive?
  1. RC Cars for Sale [MELB]
    By malk234 in forum Other Items for Sale
    Last Post: 1st May 2012, 11:13 PM
  2. Drift RC - CHEAP!
    By Low Style in forum Other Items for Sale
    Last Post: 10th October 2010, 10:08 PM
  3. sa..for sale 2x nitro rc drift cars
    By sly1 in forum Other Items for Sale
    Last Post: 21st January 2010, 09:29 PM
  4. rc drift
    By stinger_007 in forum General Topics (No Technical Questions)
    Last Post: 31st August 2006, 10:17 AM
