Page 3 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 151
Thread: Drift RC Cars
  1. #21
    Veteran slydar's Avatar
    Dimitri
    nah, TB03. shaft car. but same suspension etc.
    78's
  2. #22
    Veteran corknose's Avatar
    Callum
    thats why i thought so, why did u go shaft?
  3. #23
    Dimitri
    1. tbh, if youve had a chance to try it out rc drifting, and like it, then maybe just get a TBO3 or TA05. these cars need zero hop ups. they come with all metal drive train, full bearings, etc. if you can pick on with a body you like, then that makes things alot easier.
    all shells are compatible with other chassis. all the car used for drifting are the the style 1/10th EP (electric powered) touring cars (4wd). you will just have to estimate/work out where to put the holes for the body posts if you mix manufacturers.
    my car is a HPI shell on a tamiya chassis.
    all touring cars just about, use the same wheel hex's are are therefore compatible. again, im using HPI wheels on my tamiya.
    normally, wheels are a 0 offset, some tamiya stock wheels are -3. offset is the same as cars, but opposite. -3 is 3mm further in, +6, 6mm further out.
    radio gear, just get what youre willing to spend. i had futaba JR which ozrc has for like $40 for a full set. recently upgraded to 2PL 2.4ghz so i dont have to worry about frequencies when i got to tuesday/thursday meetings, but it was $200 without for just a transmitter and receiver, no servo.
    batteries depends on what motor you run a bit. i found my TT with a 19t ran for ages on a 3300mah NIMH battery.
    when i changed to brushless, i was getting pretty shit run times, so upgraded to lipo, but you do need a fair bit more exxy charger. batteries are .2v more powerfull, run harder right up untill theyre "flat" and you get way more cycles out of them before they start to die (performance drops away).
    78's
  4. #24
    Dimitri
    wow, typo town. anyway sure you can decipher it.
    78's
  5. #25
    Brendan
    Yokomo mr4tcsd
  6. #26
    Callum
    NEVER EVER EVER EVERRRR RUN A LIPO FLAT!!!!!!
    yes i will never use a nihd battery again just wasting time lipos you can get close to an hour.
  7. #27
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Talking
    yea never run lipo's flat they don't have a memory like most batteries and if they go flat they simply die
    should i get my FULLY sick drift team losi BK2(its a 2wd buggy that drifts nice in dirt)with the 13x2 motor, hand wound, blue printed and FUCKING FLYS
  8. #28
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    do oz rc stock these tb03 and ta05, and how much do they go for??, i think im gonna drop into a hobby store and have a good long chat about whats what, etc. thanks for the reply dimitri, sort of get it and sort of have to do more homework.
    are there any aus based drift rc forums i can read up on???
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
  9. #29
    Callum
    briz drift is good not sure if its alive. down under drift or something is another
  10. #30
    Trung
    Keysborough
    With Li-Po battery packs, you can (recommended) get Li-Po 'cut-offs' so once the battery pack gets to a certain limit, it cuts out alot of the power to let you know that it now requires charging.
    As for fitting bodies of different makes to different chassis, here's a tip. Before painting the body, place it over your chassis body mounts and with a permanent marker, mark out the dots for the body posts. This is once you have aligned/offset the wheels correctly. In some instances you may have to cut out the body.
  1. RC Cars for Sale [MELB]
    By malk234 in forum Other Items for Sale
    Last Post: 1st May 2012, 11:13 PM
  2. Drift RC - CHEAP!
    By Low Style in forum Other Items for Sale
    Last Post: 10th October 2010, 10:08 PM
  3. sa..for sale 2x nitro rc drift cars
    By sly1 in forum Other Items for Sale
    Last Post: 21st January 2010, 09:29 PM
  4. rc drift
    By stinger_007 in forum General Topics (No Technical Questions)
    Last Post: 31st August 2006, 10:17 AM
