Results 1 to 9 of 9
Thread: Radiator/Intercooler mounting and Shroud
    Veteran bigm's Avatar
    Gold Coast
    Default Radiator/Intercooler mounting and Shroud
    Hey guys
    just wanting to know whats the go with the best way to mount my radiator/intercooler combo in my engine bay. I am under the impression building a shroud will improve the flow and reduce heat transfer from rad to IC.
    what i had planned....
    15-20mm gap between the rad and cooler with a shroud either side and on top. so the air doesnt get stuck there, the air goes through the IC and then is pulled through the radiator by the thermo fans. this means the heat is moving away from the cooler and towards the motor.
    correct me if im wrong. works in my head so its probably fucked lol
    Veteran Rice86's Avatar
    Richard
    Liverpool
    off topic but WOW you got so much space in that bay...
    to mount the FMIC + radiator behind the radiator support...noice
    dose
    Senior Member resol's Avatar
    steve
    vic
    yeh what you said sounds good. you can also make air dams from the front of the car to the IC for that extra special airflow.
    FYI the first time my mate fit his IC, the rad was maybe 10-15mm from the cooler and it got heat soat (this was with a 16" thermo fan). with that space i'd maybe make it more lik 40mm+ if you could.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    Yea, heat soak is no-good. The further apart the better, and you have wicked space in that bay! Engine mounted nicely over the front axle.
    Gone
    Joel
    Picton
    hehe like the use of swaybar D clamps to mount the intercooler...
    i think mounting the IC so close the the hot radiator is no good... to much heat soak..
    Your on the right track but i feel the best thing to do is:
    Mount the IC in undisrupted air flow, maybe infront of the rad support
    Make an enclosed shroud around the back side of the radiator that is sealed and mount the fans in the shroud, it creates a greater vacume effect and makes the fans more efficient drawing air through the entire core instead of the surface area where the fan is mounted.
    i think with your idea of mounting the cores close and making a way for the air to flow straight from the IC into the RAd... your really channeling "warmed" air and turbulent air from the IC into the rad core.
    Gold Coast
    haha the clamps are the only thing i could find that would work at all.
    thanks for the ideas guys, going to have a play with it now, ill put another pic up when i have dummied them up again.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    V mount..!!!
    Veteran shift_rook's Avatar
    SE Burbs
    v mount would be badarse, top setup man, looks sick
    Gold Coast
    v mount would be sweet.
    but cant afford it. i have other places id rather spend money, as it is now there is 60ish mm between rad and IC, should be sweet
  1. Intercooler mounting
    By Greene in forum Technical - Questions
    Last Post: 7th April 2009, 09:33 PM
  2. AE86 radiator shroud (Brisbane)
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 09:45 AM
  3. Thermo/shroud that suits ke Radiator?
    By v-tec in forum Technical - Questions
    Last Post: 8th February 2009, 09:30 PM
  4. AE86 radiator shroud
    By mc68 in forum Cars or Parts Wanted
    Last Post: 25th May 2008, 09:45 PM
