Results 1 to 10 of 20
Thread: 20v block to Gearbox
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    Default 20v block to Gearbox
    How many bolts are there?
    Also is there a need to mount those little bracket things that come on the jdm 16vs that go from block to gearbox?
    todd
    7 maybe in total? maybe 8 there are two types though, smaller 14 heads x5 or 6 and 17s x2.
    and nah u dont need those little brackets, only dead weight really.
    unless u want it to be all stock and nice then yeah a little more bracing cant hurt.
    Jun 2009
    Damian
    but they dont seem to line up or is it me?
    todd
    the brackets or the bellhousing?
    bellhousing is direct fit. no problems there.
    brackets who knows? someone else will be able to confirm but i was under the impression only 7a blocks didnt have the provisions for the brackets.
    Veteran Skylar's Avatar
    Ken
    Those bracket things suck. They don't even line up on normal 4a.
    It's all to do with the sequence you tighten the bolts up in.
    Sutherland
    Yeah the brackets didn't line up on mine either so I left them off
    I think I only ended up using the 4 17mm headed bolts to fasten it.
    Toyota love to over engineer everything.
    Jun 2009
    Damian
    it just seems that only 4 bolts is rather weak!
    todd
    use all the bolts. it would suck to have your gearbox just jump off during some mad hill run.
    but forget the brackets.
    Jun 2009
    Damian
    yeah but todd there is only 4 two up the top and 2 down the bottom??
    todd
    6 is kind of close to my guess of 7.
    whack some gaffa tape on there to be sure and ur SWEEEEEEET
  1. 16v head on 20v block
    Last Post: 30th October 2010, 06:27 PM
  2. 16V head on 20V ST block
    By naksutaung in forum Technical - Questions
    Last Post: 22nd March 2007, 10:45 AM
  3. conflicting information about 20v on 16v block
    By hillclimb86 in forum Technical - Questions
    Last Post: 3rd October 2006, 11:14 PM
  4. 20v on a gze block
    By omy in forum Technical - Questions
    Last Post: 6th May 2006, 07:23 PM
