Results 1 to 6 of 6
Thread: best and easiest way to hook a horn up
    Senior Member bams_keto's Avatar
    Stephen
    Sutho Shire
    Default best and easiest way to hook a horn up
    hey guys
    failed my blue slip coz i didn't have a horn so i'm just wondering wats the best way at going about putting one in and getting sweet to pass blue slip??
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    best way is to wire it up as per factory wiring there is 2 black lugs on the body wiring loom on the rad support they are the horn sig and the body is the earth you will need a Toyota factory horn for this to be an easy task this is a very simple task i thought you would know this sort of shit
    the dyno pull to 300rwkw
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    You've probably still got the actual horn piece attached to the rad support. Find the wire for it, If it has them plugged in, Find out why it doesn't beep on the horn button. Pull the horn pad off and have a look. I didn't notice if you had a std wheel or anything, But you have a boss kit check that the wire in that is good.
    FTP.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    pen15 is on the money
    Veteran Rice86's Avatar
    Richard
    Liverpool
    dodgy blue slip always helps
    dose
    Senior Member OMG866's Avatar
    Nick
    Miranda
    wind window down ( shout BEEP BEEP )
  1. What is the cheapest/easiest way to get into rally.
    By anastasios in forum Dirt and Offroad
    Last Post: 28th April 2019, 09:56 PM
  2. hook a brother up
    By fantapants in forum Cars or Parts Wanted
    Last Post: 13th July 2011, 11:42 PM
  3. easiest way to lower a ke70 wagon
    By thekid in forum Technical - Questions
    Last Post: 25th May 2009, 09:46 PM
  4. easiest AE86 Swap
    By A.Short in forum Technical - Questions
    Last Post: 31st March 2008, 05:06 AM
  5. DA was off the hook
    By AE71 Rolla in forum General Topics (No Technical Questions)
    Last Post: 25th February 2007, 11:55 PM
