Page 10 of 31 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... LastLast
Results 91 to 100 of 301
Thread: F series Diff info + Discussion
  1. #91
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Got this info from toymods GA61XX
    this is for a mx13
    Axle set :- 2053 kit = $34.62 a side x 2 = $69.24 BSC?
    pinion seal :- M1067 = $3.87 x 1
    pinion front :- 30306 = $23.60 x 1 TIMKEN?
    pinion rear :- 32307 = $28.40 x 1 TIMKEN?
    centre bearing outer :- 17831 = $19.25 x 2 = $38.50 NSK?
    centre bearing inner :- 17887 = $50.2o x 2 = $100.40 NSK?
    Total = $264.01 +GST = $290.41 full set..
    cheeper centre bearing's :- NTN. = $15.60 & $31.80
    Total = $219.91 + GST = $241.90 full set.
    Anyone got info for the yr22 diff or is it the same
    I found the 2053KIT on a BSC site and it also goes on the yr22
    but the others im not sure.
    also after gaskets. I need to get my car rolling asap.
  2. #92
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    got it going yet bud?
  3. #93
    Kaan
    Emerald
    nup found bearings from bsc $138inc for all seals and bearings. going to get them saturday. sounds too cheap though
  4. #94
    Jack
    Blackmans Bay
    I've just looked up all the part numbers required and sent them off for a quote
    when i hear back ill post here for everyone
  5. #95
    Jack
    Blackmans Bay
    best i can do for all seals for pinion and diff centre is $310 plus post all genuine
    wheel bearing kits $170 a side
    It would deff be interesting to see if repco kits made for hilux diffs would fit F series
  6. #96
    Dec 2009
    Andrew
    California
    Nothern
    USA
    I used a truck/hilux kit from a 4x4 place for mine when I changed ratio's.
    Andrew
  7. #97
    Jack
    Blackmans Bay
    yeah awesome makes things alot cheaper
  8. #98
    May 2011
    Ed
    Wynyard
    ecko, you doing the f series conversions or jus helping supply bits needed?
    also you know if crawfg is running an f series? i'm dead keen on one and wanna keep the rear end drum, which i'm thinking most of them are??
  9. #99
    Jack
    Blackmans Bay
    nah im just selling the bits,
    Lloyd can do the conversions tho as he did mine,
    Yes crawfdog is running F series as drum
  10. #100
    Jack
    Blackmans Bay
    and progress DRFT86?
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
