anyone have a manual of how to pull apart and overhaul an f series??
tarago and spacia YR22 are the same yeh?
its the same as every other diff haha?
Sorry I meant like specs on the centre etc. never rebuilt a centre before
I've got 2 or 3 sets of F-series specs. I would use these, 'newest' ones I listed off the Tacoma/Hilux.
From here:
Also, if you have not EVER rebuilt/built a differential. Get someone that has done them successfully to help/do it for you... or worst case pay someone. It's not just a spec deal, it takes a bit of hands on experience before you will understand how to do it right.
Andrew
does any one know (actual numbers) how much weight this conversion adds?
for example T18 v's Yr22 complete set up?
78's
id say at least 10kg if not more
was putting together my diff today. ran into a lil bit of trouble. all my bearing were correct except the ones that go onto the new trd 2way 41301-RA010 centre. I got all the bearings and seals for $253 from a bearing place. The centre bearings were correct for the old centre.
does anyone know the correct bearing part number?
Ill be going to the bearing on monday to see place to see about an exchange for something that fits.
also getting a new collapsible spacer and new pinion nut.
Edit: the inside diameter of the old bearing is 45mm the trd centre is 50mm
32010X is the bearing you need for the centre thanks assassin (Andrew)
next question for me what did everyone do for their hand brake cables?? and pics if you have any. I will be using drums
im yet to get mine made
