Has anyone tried these 4wd C&P kits?
Made?? Or u going to modify the plate?
Unfortunately the listing doesn't say if it's a standard rotation (what you need for RWD applications), or reverse (Split case/clamshell) IRS.
I'm currently running a 4.88 from here, in my f-series:
Andrew
Handbrake setup
what cables? standard 86?
yep i loosened off the hand brake as much as possible. just waiting on new brake shoes and cylinders. also need new axle seals I whacked em in and stuffed em
oh yep, let me know how it goes,
pretty sure ill just get custom cable though
DR86FT can you do a final write up in this thread once you have fully completed your LSD install,
If you can be arsed, a list of all part numbers and where you sourced stuff would be really appreciated.
yep will do ill keep my receipts etc
I have 2 F series diff for sale if anyone is keen
