Page 3 of 31 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 301
Thread: F series Diff info + Discussion
  1. #21
    Anthony
    Thanks, no wonder they're so hard to find!
    Kona, some YR22's have the 54.8 drive flange, its luck of the draw. They're interchangeable anyway.
  2. #22
    Veteran Konakid's Avatar
    Henry
    Eastern
    Really? Word.
    Will have to measure mine to check, maybe it was different from the auto to manual diffs? Mine was an auto.
    Hoping mine is 55!
  3. #23
    Senior Member vivioman's Avatar
    Vernon
    Aveley
    Can the gurus tell me what is involved in replacing an S series diff with an F series (F372)?
    Would major mods be on the cards i.e. replace whole axle or just the diff centre (if this is possible).
    Thanks
  4. #24
    Darren
    for you dude bein in wa, take your f series an s series to driveline engineering, they have a jig premade for this conversion an they swap the mounts over so its a straight bolt in, then just get the handbrake cables modified and tailshaft modified. $1000 change over max
  5. #25
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Done a F-series diff using the mounts from an S-series on my AE.
    See here, did a write-up on it:
    Andrew
  6. #26
    RaY
    Anybody know the average price to get the mounts swapped over from a diff shop???
  7. #27
    Henry
    Eastern
    500 minimum if they have a jig
    If they have to make a jig, prob 800
  8. #28
    Anthony
    where are you? If youre in Bris we can do it for $350, both housings supplied bare.
  9. #29
    Senior Member OMG866's Avatar
    Nick
    Miranda
    ^^^^^ why cant we have more ppl like you in Syd
  10. #30
    Brad
    Central coast
    send it up. thats what i did. still works out cheaper than around here.
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
