Page 5 of 31 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 301
Thread: F series Diff info + Discussion
  1. #41
    Senior Member tin can's Avatar
    Jess
    guys silly question how many spilnes on a F series axle.
  2. #42
    Anthony
    twentyseven
  3. #43
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    so just a quick question
    the LSD from Altezza will fit?
    now im guessing its the sxe10 or gxe10 as they are 7.5 inch as is the F series,
    jce10 and gita are 8"
    also the spacer ring i cant find any info on, anyone have pics?
  4. #44
    Member Sorry_Afk's Avatar
    Dec 2010
    Adam
    The Grove
    I've got an F series from an mk2 corona, and the rear drum adjustments don't work, or become unstuck, does anyone else have this problem? If so how did you fix it?
  5. #45
    Member DRIFTRT142's Avatar
    Jan 2011
    Mark
    Seaton
    I also have possibly a silly question. My rt142 doesn't have anything stamped on the diff/axle spot on my I.D plate but I'm pretty sure the IRS models have an F372 (correct me if I'm wrong) are these able to be shimed or is welding my only option to lock it cheaply. She's a budget box so I don't wanna buy a locker or anything but I'm wondering what's possible to do with them before I pull it apart this Wednesday!
  6. #46
    Jack
    Blackmans Bay
    so any f series diff gears would fit a f series solid axke diff? meaning ra65 ma61 cressida soarer etc would fit?
  7. #47
    Senior Member Rip it's Avatar
    Jake
    Correct, Capatin Jack. ANY 'F" is 7 1/2" crown wheel. Good ratios too, if you know where to look.
    I got nothing.
  8. #48
    Jack
    Blackmans Bay
    cool now to find the ma61 lsd ive got laying around somewhere
  9. #49
    Veteran Konakid's Avatar
    Henry
    Eastern
    Apparently they are a shitty cone type? Not worth it ive been told.
  10. #50
    Jack
    Blackmans Bay
    pinion is interchangable too?
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
