Page 7 of 31 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 61 to 70 of 301
Thread: F series Diff info + Discussion
  1. #61
    Glenn ke_70's Avatar
    Clay
    Barossa!
    weldies only suck for u turns or pushing car around
    where do you get 4:7 ratios or there abouts from?
  2. #62
    Dec 2009
    Andrew
    California
    Nothern
    USA
    I got 4.88's from a 4x4 place I found through from when I was into 4 wheeling... until I found drifting. About $190 USD for it brand new.
    Although, I have been thinking about going to 4.56's.
    Andrew
  3. #63
    Member DRIFTRT142's Avatar
    Jan 2011
    Mark
    Seaton
    Hmmmmmm interesting. thanks guys! Just wanted to check cos ive heard there are a couple of toyota diffs around that are a pain in the ass to weld up. But il crack it open tomorrow and give it a whirl! Many skids are to be had!
  4. #64
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    what other diffs can i get the mounts off to do the conversion?
  5. #65
    Senior Member Stain's Avatar
    Derek
    Far North
    Anyone got any info on the '90s TCR10 Tarago diff/live axle?
    Is it also a F-Series? How wide compared to the YR22?
  6. #66
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    It is not a f series afaik
  7. #67
    Senior Member PRIMRK's Avatar
    Dec 2009
    Cameron
    Brighton
    Ive got one of the F series out of a tarago but have no brakes on it, are there any disk setups i can get that will bolt on to this?
  8. #68
    Kaan
    Emerald
    I think people have adapted disc setups but either they change the flanges or the just make custom brackets.
  9. #69
    Jack
    Blackmans Bay
    there is a guide on toymods to doing ma70 brakes onto them
  10. #70
    May 2010
    So you can go to a wreckers and just take the rear end brakes of a YR22 tarago, that should bolt up?
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
