Made a successful trip to the wreckers today, picked up some hose fittings for an oil cooler I've had for ages. Its a commonwhore item, prob around 250ml, about half the size of my current one which is half a litre and total overkill. That one has barb fittings which are a tab small for 3/8th hose. The smaller one has metric female flare fittings so I grab a pair. Only problem is they are crimp type but a removed them with the dremel! Perfect now as they're angled which saves the hose flexing! Should relieve the low oil pressure issue seeing as it's less volume but retains similar cooling properties as it's the same dimensions.
Also grabbed a Kenwood CD player, shit load of red stereo power cable, few 2 pin plugs, smallport oil return line, sandwich plate banjo and bolt, door lock switches and other small shit. Good day.
