yep hook it up likenormal
Car - MX73
motor - SR20DE+T
use - Not Much ATM
problem - Want to know if i i can put boosted air through the vacuum line that goes to the brake booster from the intake manifold. I think it should be right, but havnt had a turbo motor before so checking.
occurs/started when - I put the motor in
personal situation - I either put it on or i dont.
AE86 THE BEST
There is a 1-way valve, so retain it, and make sure it points the right way.
Thanks guys
The valve is in the booster or the line?
This. It's a little white / beige dinger that has a bracket attached to the firewall.
The one that isnt there. that would be right.
are they model specific of generic?
Pretty generic.
KE70
AE71
AE86
Appreciate that Javal. Thanks
Ill locate one on tuesday
which way is the correct way? air flowing to the Booster?
