dont happen to wanna sell the brackets that are bolted to the head unit do you? if you will ill take them.
ALL OFFERS CONSIDERED.
PM ME.
NEED TO GET RID OF THIS!!!
special!
$100 for the 6kg 200m free height AJPS springs.
be quick!
hi guys, i will be doing each of the items on special starting with the 6kg springs! the next item to go on special will be the LEVIN guards!
cheers guys!!!
- location is Vic - western suburbs
- contact by pm please
- will post at buyers expense
- feel free to ask any questions.
1. extreme 200mm bigport HD 4 puck clutch with pressure plate and thrust bearing
- brand new
- $350
4. JVC head unit
- condition is fully sik
- pulled out of my 86, worked well
- $100
5. AJPS 6kg 200mm free height front springs
- good condition, couple paint chips
- $100!!!
7. interior trim head deck surround?
- near new condition
- $40
8. T series zenki flange with open centre and 4.1 CW + P
- VGC crown wheel and pinion, pulled out of a low km t-18
- $200 - can supply spare centre welded or still open for an extra $50
9. 270mm chopped springs out of some car?
- stiff, around 4-5kg?
- $50
10. WELDED zenki centre
- good condition, use to pass roady or weld up and rip some skids with a locker
- $50 - CENTRE HAS BEEN WELDED
11. AE86 panhard rod
- good condition with near new bushes
- $50
12. 2x sets of AE86 LCA's.
- ball joints roll smooth, bushes in good condition.
- $50 a set - $80 POSTED FOR BOTH!!!
15. catalytic converter, have been told its a "high flow"
- 2.25 inch? in and out
- good condition, not "punched in"
- $100
17. ADM rear bumper with brackets in white on black panda
- VGC condition
- $100
18. AE86 caster kit
- good condition, one side has a slight bend
- $50
19. 300mm free height springs
- clear your defects
- $50
20. AE86 FRONT 21mm sway bar
- good condition
- $100
21. Excel G short stroke inserts
- great condition, no leaks
- $200
22. Kouki welded centre (no CW)
- locker fun for all you late model (big axle) diff users
- about 1kg of slag in it
- $100
24. Front right and left LEVIN guards
- good condition
- minor dents
- $150
ADM washer bottle and overflow thingy
$60 posted
Willans 4 point harness
$200 posted, can come with free black pug
JDM? passenger seat with rails in great condition. no marks or rips
- silvertop quad throttles with gasket!
$275 posted anywhere in AUS.
- "Monroe originals" rear ae86 shocks in great condition - no leaks
$75 posted anywhere in AUS.
Thank you for looking!
there yours for $20 posted
i'll pm you bank details.
-coily sleeves SOLD PP
-JDM callipers, backing plates and disks SOLD PP
sparco genuine?
yes siree
edit: will seperate rail and turn seat into a computer chair if rail is sold alone
hi there, any noise on the zenki diff? if not i'll take it. thanks
do those sleeves come with upper spring perches with undrilled pilot hole?
what suburb?
hello, if you are reffering to number 8. then no, no noises.
i purchased a t-series flange with an LSD and 4.7's so just basically did a straight swap.
ill pm you bank details?
let me know.
cheers mate.
sorry mate, sleeves are sold PP
no upper spring perch, just what you see in the photo.
if that falls through its yours.
edit: suburb is footscray
seat - SOLD
calipers, disks, backing plates - SOLD PP
4 links - SOLD
