Since 4agze's have a larger crank pulley to overdrive the supercharger, you cant set the timing properly as its not really visible to line up (specially in fwd format). If you see the manual, it will show you what it's for. The 0deg mark does not match up with the numbers on the cover but there are 3 notches marked on the crank pulley to line up with the pin
