Results 1 to 5 of 5
Thread: RWD waterpump onto FWD engine
    Nick
    western suburbs
    Default RWD waterpump onto FWD engine
    i have a 4AGE 16v bigport from a AE82 and i'm putting it into my AE86, just wanted to know if you can put a RWD waterpump onto the FWD engine and willl it work right?
    also can i still use the FWD flywheel or will i need to change it to fit the RWD gearbox/clutch?
    Jonathan
    You can put a RWD waterpump on, but to make it work properly you need to change a whole bunch of parts also, which I think is worth it in the long run.
    whole waterpump (both halves)
    RWD 4A-C or 4A-GE thermostate housing
    waterpump pulley
    alternator brackets
    4A-C or 4A-GE RWD heater tube
    The FWD flywheel and clutch is the same and can be used. You just need to put a little bearing in the crank.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    while on this topic.. plan to do the same with my 20v conversion... do I need to change the crank pulley also? I cant quite remember... (when using a rwd water pump pulley)
    BENT MECHANIX - Garage 20:
    Jonathan
    No, the crank pulley can stay.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    All you need to run a RWD pump is the RWD pulley.
    You don't NEED as such any of the other gear listed, but its a smart way to go for an engine you are converting to RWD.
  1. thermostat housing off a RWD waterpump
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 23rd February 2009, 06:17 PM
  2. 4ac waterpump same as 4age rwd waterpump?
    By simonster in forum Technical - Questions
    Last Post: 25th October 2007, 10:11 PM
  3. WTB ASAP-RWD WATERPUMP PULLEY
    By james86 in forum Cars or Parts Wanted
    Last Post: 2nd July 2007, 08:24 PM
  4. fwd to rwd engine bits
    By sik-86 in forum Technical - Questions
    Last Post: 12th February 2007, 08:50 PM
