updated with pics
Car - toyota ae86
motor -4ac
use -daily
problem -i cant get the top braket that holds the steering rack down to come off, i have completely removed both bolts and got it to move, but due to clearance issues from the gearbox and bottom of the engine i cannot actually get the bracket out, it is on the drivers side, the opposite side was fine and had no problems atall, but this one just wont come out, i need to do this to replace the rack bushes with new ones. o if anybody knows any tricks or tips that might help. pleasee let me knowcheers
pics (sorry for the shitty camera phone pics)
in place with bolts out:
at the closest point to being out:
occurs/started when -5mins ago.
personal situation - just need to get it done
thanx![]()
updated with pics
it does come out, and it is a bitch, i remember having the same issue, but its even funner trying to clamp down new bushes, if their urethane..
will it go over the front of the x member? their is light, it does come out!
shtis a bitch to do. i seconds.... took me many tries after giving up many times. tip wear goggles, shit falling in the eye pisses you off
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
Are you able to try and lever it out
if you force shit enough, you shouldnt have to even get the bracket out.
Or -> unbolt gbox mounts and engine mounts and jack that shit up!
Unbolt the steering rack from intermediate shaft would be the easier way.
Did a pair in 20 minutes no worries not 2 weeks ago.
got it all done like just after i posted thisi ened up jacking the front wheels off the ground, then turning the wheels full lock left with both brackets unbolted, which in turn moved the rack to the right as it was not bolted down, then i just used my hands to push it the rest of the way, then i had great clearance, then slid it back across and bolted it down once the bush was replaced, the only problem now is cause of the new bushes i cant get the main top mounting bolt back in cause it all sits too high and forward, but ill try something tomorrow
than all for your help![]()
your just silly, sit bac and look at it and think for 2 seconds
Whatever you do, dont try clamping/applying pressure from just the top. they are way to thin and just bend the wrong way!
