Results 1 to 5 of 5
Thread: Caliper mount bracket/dust backing plate - Torque specs - AE86 or simular
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default Caliper mount bracket/dust backing plate - Torque specs - AE86 or simular
    Hey guys,
    Iam just in the process of installing a brake kit (Hopper Stopper) in my AE86.
    But I am having trouble finding the bolt torque specs for the bracket that mounts around the stub axle, AKA bracket that the calipers mount to AKA dust backing plate (4 bolts (7T's)).
    I have the Manual for the AE86 and a few other corolla and crown manuals too, but nowhere does it have the torque specs for these actual bolts. I have done a net search and found nothing.
    I Have done one side or the car and torqued them up to the same recomended torque that the actual caliper mounts to the bracket in question, which is 58 ft-lbs. But I thought i'd better check this before going further, incase it's not sufficient.
    If someone has these bolt torque specs or can give me some idea of how tight they should be, that would be great.
    Thanks,
    JoJo
    Gone
    Joel
    Picton
    I wouldnt worry, same as the caliper bolts should be fine.
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    say around 30 to 40nm.. without checking,
    i just do them up tight enough so they wont come loose..
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    what i did, i used two of the original size bolts and two that are longer by about 15mm.
    then i just placed a nut on the end of each longer bolt just as an extra precaution.
    also used medium strength lock-tite on each bolt and nut.
    i think using 4 standard bolts with lock-tite is enough but its up to the individual i guess.
    Mark
    Southern
    i always assemble every thread with moly' grease ensures correct torque tension is achieved so the bolt wont come loose..
    also makes things quick and easy to work on when replacing stuff at the track and ensures threads/bolts stay in good condition
    not many things on a toyota that has thread locker on from factory.. only holden and ford do that
  1. Ae86 hubs, caliper brackets and backing plates SYD
    By Sprinter Freak in forum Cars or Parts Wanted
    Last Post: 19th June 2012, 01:55 PM
  2. AE86 brake caliper brackets and backing plates
    By slide86 in forum Car Parts For Sale
    Last Post: 4th December 2011, 03:45 PM
  3. Urgent - front caliper backing plates from ae86
    By Catch My Drift in forum Cars or Parts Wanted
    Last Post: 11th February 2011, 02:40 AM
  4. Rear brake backing plate and Dust Shield Problem...
    By J_D in forum Technical - Questions
    Last Post: 9th April 2008, 07:35 PM
  5. Replies: 2
    Last Post: 8th April 2008, 02:07 PM
