Page 8 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 71 to 80 of 199
Thread: ill-minded's L70/L80 Mira
  1. #71
    Ian
    If I were to paint it that colour again, I'd want to get it colour matched, then get a proper paint job done, cause it faded something chronic. It'll probably stay the faded red for a little while yet, anyway.
  2. #72
    Ian
    Cause a picture says a thousand words. Unfortuately, they don't always explain the background story. In a nutshell, I finally got the centre bores machined out on the 13" steelies I've had for ages so they now actually fit on the hubs. Props to Dr. Wheels down on the coast for the machinework. Threw them straight on the lathe for me, took all of 20 minutes and only cost $40 to do the lot.
  3. #73
    Glenn ke_70's Avatar
    Clay
    Barossa!
    put a turbo motor in it! lol
  4. #74
    Ian
    Haha. I don't know if I could be bothered doing that. Far too much money involved. I'm trying to restrain myself from spending too much on this thing so I can allocate more to the main source of spending (the Celica). Having this as a cheap daily is a much better prospect at this point. When I'm making a bit more money I might look into doing something a bit more exciting in the power department.
  5. #75
    Ian
    Almost there...
  6. #76
    Ian
    Now cruising the streets.
  7. #77
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    Cuuuuuttteeee!!!
    Next modification should definitely be a cut and polish.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
  8. #78
    Ian
    Yeah, it does need a bit of love in the paint department, but it's not a high priority right now. You can see in that last picture the top driver's side corner at the back where I "polished" the paint (with a rag doused in acetone...) and it came up pretty good underneath.
    Here's what the plugs looked like when I pulled them out earlier. Needless to say, I'll be off to get some new ones tomorrow.
  9. #79
    It ran on that shit? haha..
  10. #80
    Ian
    It also ran with the ignition timing on full retard. Go figure.
    It runs pretty good now that I've fixed the timing and replaced all the service items. It used to struggle to pull up hills in third, but now I can pretty much pull up hills *just* in fourth. Runs a lot smoother and idles properly. It also sounds pretty awesome, even with the standard exhaust.
  1. ill-minded's RA65
    By ill-minded in forum Other Toyotas
    Last Post: 10th March 2016, 10:49 PM
  2. crazy 86 lover not to mechanicly minded help plz
    By dtp05 in forum Technical - Questions
    Last Post: 4th May 2009, 09:39 PM
  3. Replies: 4
    Last Post: 27th February 2008, 07:53 PM
  4. ill draw your car
    By HiLtOn in forum Toyotas in the Media
    Last Post: 2nd May 2007, 04:36 PM
