Page 9 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 81 to 90 of 199
Thread: ill-minded's L70/L80 Mira
  1. #81
    Glenn ke_70's Avatar
    Clay
    Barossa!
    wait so this is just the standed 850cc motor that your driving around? or the built 850/660 hybrid?
    i may be looking at building up a hybrid motor for mine. what are parts like to get? like pistons bearings head/gasket sets ect ect.
  2. #82
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    not trying to plug but, these would look cool.
    13x6 +offset CSA globlines (mk1 looking things)
    buy these off me, will fit nicely.
    ~KEEP DRIFTING FUN~
  3. #83
    Mereki
    Badassville
    they have gay tyres on them, but with some 155/165's on them will be winner
    ~KEEP DRIFTING FUN~
  4. #84
    Clay
    Barossa!
    are they 110 pcd?
  5. #85
    Mereki
    Badassville
    4x100, damn thats right
    ~KEEP DRIFTING FUN~
  6. #86
    Ian
    Nah, just running the standard ED-10 at the moment. The hybrid will come a little later if I can be buggered building it up and shelling out for all the machining and new seals, bearings, etc.
    Last I checked, a full gasket set was about $250 and all the bearings were another $100 or so. Not sure how much new pistons are worth, but any Toyota dealer should be able to look up for you. You should be able to pick up spare motor bits from someone who has done a swap for a turbo motor, or someone who has replaced a motor. Also keep in mind that the hybrid motor is theoretical at this stage. I've never seen one done, but it all works in theory. i.e., the head will bolt up to the block and you can use the same timing belt, dizzy, etc. The compression ratio will be rather high too (13:1 or thereabouts from rough calculations), so take that into consideration.
    trikzlane: Already got some new wheels in Japan. Thanks anyway.
  7. #87
    Clay
    Barossa!
    you wouldnt happen to know the 660cc CR?
  8. #88
    Ian
    I do indeed.
    EF-EL (660cc) is 9.8:1
    ED-10 (850cc) is 9.5:1
  9. #89
    Clay
    Barossa!
    ah sweet thanks
  10. #90
    Ian
    Yes, that is a giant dick on the hatch.
  1. ill-minded's RA65
    By ill-minded in forum Other Toyotas
    Last Post: 10th March 2016, 10:49 PM
  2. crazy 86 lover not to mechanicly minded help plz
    By dtp05 in forum Technical - Questions
    Last Post: 4th May 2009, 09:39 PM
  3. Replies: 4
    Last Post: 27th February 2008, 07:53 PM
  4. ill draw your car
    By HiLtOn in forum Toyotas in the Media
    Last Post: 2nd May 2007, 04:36 PM
