Page 13 of 20 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 121 to 130 of 199
Thread: ill-minded's L70/L80 Mira
  1. #121
    Senior Member KE20's Avatar
    Feb 2010
    Haydn
    South
    how would these go fitting on one of these?
    10 inches ×7J, offset +9
  2. #122
    Ian
    If I could afford them, I'd make them fit. The set on Yahoo at the moment starts at 100k. They'd be about 1-1.5" out of standard guards though.
  3. #123
    Feb 2010
    Haydn
    South
    yeah they are the ones on yahoo
  4. #124
    Ian
    Got this thing running properly today. Still needs the fuel map tweaked and the interior bolted back in properly, but...
    HOLY SHIT THIS IS QUICK.
  5. #125
    Aug 2010
    Adrian
    South
    Vids and pics asap
  6. #126
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    looks crazy, love that you have fitted itb's
    Just another Muppet
  7. #127
    Ian
    It looks the same as before pretty much. Once I sort out the interior and tidying up some of the interior wiring, I'll get some vids of it running. Should be done with most of that by Tuesday or Wednesday hopefully.
    Vaughn: Thanks, man. It's pretty crazy on WOT. Surprisingly, it's still pretty easy to drive around even though the throttles are probably about 6mm bigger than necessary and only having half of the pedal travel due to the smaller pulley on the bike throttles compared to the original carb. Should be even crazier once I find someone to do the exhaust properly for me too.
  8. #128
    Ian
    Just realised I haven't actually updated the pics on this in a while. It looks mostly the same as this pic, but with the filters on the throttles and the rest of the car is assembled.
  9. #129
    Ian
    Andrew
    Lenswood
    This car is so awesome!
    Thanks,
    Andrew.
  1. ill-minded's RA65
    By ill-minded in forum Other Toyotas
    Last Post: 10th March 2016, 10:49 PM
  2. crazy 86 lover not to mechanicly minded help plz
    By dtp05 in forum Technical - Questions
    Last Post: 4th May 2009, 09:39 PM
  3. Replies: 4
    Last Post: 27th February 2008, 07:53 PM
  4. ill draw your car
    By HiLtOn in forum Toyotas in the Media
    Last Post: 2nd May 2007, 04:36 PM
