AJPS Traction Brackets
Technical information
* 4mm steel plate, mig welded and braced
* Comes with all spacers and washers
* 8.8 bolts used throughout
* Two adjustment points
* Suits T18/celica/Borgy drum diffs
* Also have a disc brake rear (JDM ae86) only version
* Made in Adelaide
Blurb
* Fixes pinion angle issue in lowered corollas
* Adds traction/anti squat to the rear
* Returns rear end to factory geometry
* Australian made quality, guaranteed to fit!
Fitting Instructions
* Remove lower trailing arm
* Bolt on (there is left and right side)
* Replace arm in the desired adjustment point
Customer Reviews
"I was running wide on the high speed corners at Mallala, but now the car has so much more grip."
Colours Available
Factory look, satin black plating
Weight
2.1kg per pair ready to bolt on
Stock
6pr ADM as at 4/3/10
8pr JDM 4/3/10
Price: $195pr + $12.90 express
