Page 105 of 119 FirstFirst ... 5 55 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 ... LastLast
Results 1,041 to 1,050 of 1189
Thread: Car Updates
  1. #1041
    slydar previously put this together...ive done a copy and paste...might find it of interest/helpful nichy
  2. #1042
    Nichy
    Launceston
    SO TO SIT LIKE DAIMS (best and low) i would need to cut the strut to get the lowness i want with a full stroke..... if i dont cut it the insert will in the wrong range to work best ?
    struts are coming out tonight so will have a good look and a play and see what i can do.
    any info is handy though and cheers for the replys
  3. #1043
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    got a ke/ae 70 whiteline front swaybar for sale got lengthended control arms with nw bushes too
    pm me if your keen
  4. #1044
    Junior Member spooniluv's Avatar
    Apr 2011
    Gareth
    Frankston
    just an update, i have decided to run a carby setup on the ls1, only due to space restrictions, and ease of wiring. after buying a standard manifold i found that there just wasnt enough room to comfortably run a decent cooling system i the front. the only other option i have is to cut a huge part of the firewall out and install a rear hump sump on it but then the whole rear two cylinders will be inside the car, not what i am looking for. if anyone has any suggestions please let me know
  5. #1045
    Jack
    Blackmans Bay
    fuck that for a joke, carby setup would be horrible,
    there has to be a way around it,
    upload some pic of what your having trouble with
  6. #1046
    May 2011
    Ed
    Wynyard
    it would be nicer to keep the EFI setup as LS1s are programmable and the LS1EDIT program isn't bad at all, there are some good carb options if you must go that path, and plenty of good tuners about to get it humming, but retaining the factory efi setup makes it a bit more plug and play, and turn key once wired up properly
    carby farts are sweet tho
  7. #1047
    May 2011
    Ed
    Wynyard
    also nichy jus follow that how-to thing lazy put up that dimitri/slydar did, it's how daims, joshke's, mine, nearly everyones has been done.
  8. #1048
    Nichy
    Launceston
    ah sick will have a good read thiough then... thanks guys.....
    do i kow you dungbox ?
  9. #1049
    May 2010
    rear mounted radiator?
  10. #1050
    May 2011
    Ed
    Wynyard
    i'm ed (waves) used to be 'worked' on here mate, whether we know each other or not i have no idea, i'm very stupid and cant remember half the people i meet
