i got some ra60 ones but the bolt holes have the wrong hole centers for 86 struts
ok so found out i have 2 different length steering arms by 2.5cm........ explains alot.
so if anyone has anything p/s or not to fit corona or ae86(will make fit) that they wannt give away or cheap p/s arms then let me know asap cheers
i have corona struts in my car man....... so should be right i think..... would give me something to get chopped up
how much you want for em.. pm or msg me
I've got some stock ADM 86 arms if you want em. $20 should do, my shed needs some weight reduction.
---- Fryin Fifth Represent ----
about to order some goodies from T3should get the 4AGE closer to life and ke handeling better
bottom end is completed - top end is complete . just need to put them together.
will be looking for bolt on bit's soon re - starter , alto , dizzy , pullies.
If you need any genuine bits let me know
A front wheel drive silvertop waterpump would be nice, anyone?
unsure what gear you would be buying from T3...quads adaptor plate is about all i can think of...other better made products available locally...
MY AE86 BUILD
haha if i had ae86 struts then yeah it would be easier.
t3 steering arms to suit rt142/ra60 struts + solid tie rod end
and RCA to suit rt142/ra60 as there $50 cheaper than AJPS (with other parts)
getting quad addapter from them and vac box.... maybe crank pully
where else could i get these lazy -d ?![]()
