Stick welder? You've turned the amps down right?
Dammon. Its wont even tack dude. Fucked up
Mig bro. Yes have everything down. There are only two adjustments
Try pushing some thicker material behind if possible, ally or copper will help as the steel won't stick to it
as in in the wheel arch on the inside or between the two bits of metal ?
im guessing its just to let a bit more heat be able to come into the metal ?
cheers kieran
Oh god..... and that's why I didn't get my 195 potenza stretched onto them!!!
haha yeh the 195 is a bit much..... would go 205 lol
Cool, yeah the steel behind will act as a heat sink and also help a bit with the steel "blowing" away.
Not much of an expert with migs but I'm thinking having your wire feed too low might cause problems as well? I could be completely wrong though
Yeah cheers guys. Will give it a crack this weekend
find a decent mig with gas and prob 0.8 wire.... problem solved
