That's EFI main connection Black/Red (used to trigger ecu into ON mode, 12V on ignition). The other wire on that plug is the yellow injector wire on the old bigport loom.
Car - AE86
motor - Smallport
use - stops my axle stands floating away
problem - not sure where the wire circled below is meant to go. Its a jdm loom that has been modified over the years from bigport, to gze, to smallport with adaptronic. One end of the red wire goes into the T shaped connector near the fuse box. Can't figure out where the other end plugs in.
Ah, that sounds important! Thanks.
hahahahha about to chop it???
Ha, not going to chop it. Just trying to figure out where its supposed to go. It had a a few feet of red auto cable connected to it, but all bunched up and taped to another part of the loom. If it was connected to anything, it couldn't have been far away from that plug.
