What 4AGE block is it?
Hey guys,
Some of you will have been around long enough to remember this motor and my old car...
It's a 1.8l stroker bottom end. The crank is a custom type, maybe HKS, crank. It's NOT a 7A. The block has been machined to suit the crank, and from memory bored out to 82mm I think the pistons are.
It comes with ae111 black top 20v rods.
The pistons have been damaged due to an on track fuel pump failure. It will come with a set of ca18 pistons that need some machine work done to fit, but the old pistons will be provided as a guide for this.
This engine went very, very well. The car was very quick. It had a basic head with 256/264deg cams and a basic port and polish and made 100rwkw without being tuned. Sounded fantastic, good torque.
Selling very cheap a) Because I'm currently unemployed and need cash b) I know longer have a hachi roku and c) my next hachi roku is likely to be turbo.
With a bit of work this thing will be perfect for someone wanting a genuinely quick N/A car....
Engine located in Brisbane.
$500
0439 754 013
Cheers, Nafe
Big port block
i think he meant, "is it 3 rib or 7 rib block"
Hi Fella...
Will you take $500 posted for the crank, rods and pistons to Tas, 7292...I don't need the block, it is a pia to post also...
Put some pics up of crank or email them to me at
Very keen
Regards
Scott
Sorry buddy, $500 posted won't be enough. Postage won't be cheap. Plus the engine is not apart at the moment.
Will find a pic of the crank though if you like.
Sorry for querying the condition of this............
bump....
Bud you weren't querying.... you were making allegations... let's all grow up hey
bump...
Bump This is now at my house, so local buyers are welcome to inspect
