Results 1 to 10 of 11
Thread: t-series diff in sr20 86?
    Brock
    Default t-series diff in sr20 86?
    Car - ae86 trueno coupe 86
    motor - 4age bigport
    use -daily/drift
    problem - diff strength?
    Hi all, i am planning an sr20det build in my 86 starting around august. I am just thinking about the diff options at the moment. I have a big axle disk brake rear end at the moment and i just fitted a trd 2 way in it. Could i just get billet axles and a 4.77 cw and p or should i just sell it and get a tarago diff with an altezza lsd? thanks
    Veteran Todd's Avatar
    Feb 2010
    Todd
    SOR Perth
    T series simply will not hold up sorry. not only the axles, but the crown wheel will eat a dick.
    sell it, and use the 1000 bucks to source a F series and altezza setup.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    R31 conversions are quite easy to do too, I am on my fourth now and I am far from being the most tallented guy
    Brock
    thanks for the replies, yeah i was thinking the same thing, just wanted to make sure. so what is involved in a r31 conversion? same as tarago? If this has been covered in another thread, just point me there, thanks
    Feb 2010
    Todd
    SOR Perth
    r31 is a good option also as sam pointed out.
    essentially it's the same as doing a tarago swap, whereby cutting/moving the trailing arm mounts, cutting and moving the spring seats and getting a custom tailshaft made up will give you a strong enough rear end.
    any capable diff shop would be able to do the conversion for you but i doubt you would see much change from 1k. best option is to DIY or phone a friend who is handy with that type of stuff.
    Endeavour Hills
    got a toymods account? otherwise I should make an article about it, I havent been very motivated to write articles for a while now because of the lack of interest I have received
    Brock
    ok thanks. No i dont have a toymods account. is there any quality aftermarket lsd's for r31 diffs? Also is a r31 diff any wider than a tarago diff, thanks
    Endeavour Hills
    got any spec on how wide a tarago diff is, I will post some converison info here when I get some time
    Glenn ke_70's Avatar
    Clay
    Barossa!
    MX13 Cessida - 3.9 - 1410mm (Same as T series/S series/KE70 BW)
    Tarago YR22 - 4.1 and 4.3 - 1435mm
    Uses a G series (Hilux) diff nose tailshaft bolt pattern (60x60mm) All other F series is 55x55mm)
    there ya go sam
    curticey of konakid
    Endeavour Hills
    cool, and although I dont like being spoonfed usually how are the LSD options on these
  1. Replies: 14
    Last Post: 4th June 2012, 07:16 PM
  2. Facelift T Series diff in non 86?
    By Sambo NZ in forum Technical - Questions
    Last Post: 5th February 2012, 04:44 PM
  3. Replies: 0
    Last Post: 13th August 2010, 12:32 AM
  4. t series diff with tailshaft into 86?
    By KePanelVan in forum Technical - Questions
    Last Post: 6th June 2010, 04:08 PM
  5. T-Series Diff for 86
    By AEE86 in forum Cars or Parts Wanted
    Last Post: 13th September 2007, 04:01 PM
