Results 1 to 10 of 10
Thread: 4age ae71 brake upgrade
    Walte
    Goldcoast
    Default 4age ae71 brake upgrade
    hay guys iv done a standard 4age into my ae71 n the guys i have rang around harvey bay area say i need a brake upgrade.
    i was just wondering what some cheap options are or just not expensive setups there are.
    n if anyone around hervey bay or bundy type area has had there mod plated without a brake aupgrade
    cheers wal
    Kieran
    ae86 struts and brakes are easiest and bolt in. you can either use ADM or JDM brakes on them. or ADM calipers with larger JDM vented disc.
    or XT130 struts and brakes. Then you can do the hilux/pug upgrade.
    Walte
    Goldcoast
    cheers will i need to use a different master or any thing with the 86 brakes. n do i need a rear brake conversion as well or just front
    Kieran
    You can use the same master with the 86 stuff.
    You probably will not need to upgrade the rears but the cheapest is rt142 live axle disc brake setup which should bolt on. or you can upgrade to a JDM disc brake rear end and get the t-series as well. This costs alot more though.
    Glenn ke_70's Avatar
    Clay
    Barossa!
    what does the rt142 bolt up to???
    do they still bolt up from drums
    Walte
    Goldcoast
    yeah is there any mods u have to do for the rt142 upgrade or does it just bolt staight up
    Moderator Sam-Q's Avatar
    Endeavour Hills
    moved to tech section and renamed
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    if you have a t series drum diff then the disk brake setup will bolt straight on.
    only modification you will have to do is moving the shocker mount over so that the shocker doesnt foul the caliper. you will have to chop and re-weld the shocker mount.
    more info on the st141/rt142 brake upgrade here...
    Clay
    Barossa!
    right thanks
    would a borgy be much different? as in a few little mods and an adapter plate or somthing to make it fit?
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    dont think they fit on a borg diff
    ~KEEP DRIFTING FUN~
  1. WTB:LSD, AE71 Pedal box,work equip 01,brake upgrade,swaybars
    By psone in forum Cars or Parts Wanted
    Last Post: 21st January 2012, 04:56 PM
  2. Brake Upgrade
    By EMD-KE70 in forum Technical - Questions
    Last Post: 10th August 2007, 12:54 AM
  3. Brake Upgrade.
    By Bustin_86 in forum Technical - Questions
    Last Post: 7th May 2007, 05:04 PM
  4. Brake Upgrade
    By chasingpandas in forum Technical - Questions
    Last Post: 13th December 2005, 12:08 PM
