Results 1 to 6 of 6
Thread: Telling the difference between ADM and JDM proportional valves
    Member jamekins's Avatar
    ACT
    South Canberra
    Default Telling the difference between ADM and JDM proportional valves
    Car -AE86
    motor -4AGZE
    use -Street
    problem -need to identify proportional valve
    occurs/started when - n/a
    personal situation - I've just purchased a t-series diff with discs to replace the s-series in my AE86. I know I need a JDM proportional valve to make sure I have the right brake bias and I got the one that the previous owner was using with the diff but I'm not sure if its ADM or JDM. It has what looks to be a part number on it that reads:
    3c1
    12020
    Now according to site the part number is 47190 - 12020 for the ADM part. This seems like I may have an ADM part and it may have been gutted to get the correct bias but I'm not sure. Can some one confirm this for me?
    Last edited by jamekins; 29th April 2010 at 05:18 PM. Reason: So I don't get in trouble
    http://i187.photobucket.com/albums/x99/jumpninja/trollsigcopy.jpg
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    jdm proportional valve are 2 piece and adm are one piece. they look different, but mechanically are they different?
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
    Moderator Sam-Q's Avatar
    Endeavour Hills
    well if it has a disk rear end it has to be different
    Reeece
    Casula
    i wouldnt think there be much difference between the two, might seem stupid but i am running r32 master cylinder with pug/hilux/corona setup FRONTS and r31 disc rears, Using the ADM proportional valve and it seems to work perfect. Anything wrong ?
    ACT
    South Canberra
    Nothing wrong yet I just don't want the back end locking up all the time which is apparently what happens if you have the wrong prop valve.
    Aaron
    i did an engine conversion on a ae85 and it had the 2 peice prop valve same as my disc rear end. the brake bias on that felt the same as any other drum rear end i have driven.
  1. AE86 proportional valves (brakes n shizno)
    By rthy in forum Technical - Questions
    Last Post: 29th August 2021, 03:08 AM
  2. Difference between JDM/ADM Struts?
    By haydenz in forum Technical - Questions
    Last Post: 16th November 2009, 06:21 PM
  3. Difference between adm and jdm tanks???
    By koulouris#03 in forum Technical - Questions
    Last Post: 12th July 2009, 08:07 PM
  4. WTB JDM Brake Proportional valves
    By rthy in forum Cars or Parts Wanted
    Last Post: 28th July 2008, 05:07 PM
  5. Difference Between JDM/ADM Rear Seats?
    By WaLLY in forum General Topics (No Technical Questions)
    Last Post: 14th May 2007, 11:42 AM
