Results 1 to 8 of 8
Thread: r33/jzx100 b/m cylinder size
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default r33/jzx100 b/m cylinder size
    car-ae86
    brakes- wilwood big brakes
    is the r33 brake master 1'' or 15/16'' bore?
    if 15/16 can this be used insted of the r32?
    and whats a jzx100 brake master? i have these masters laying around at home
    Moderator Sam-Q's Avatar
    Endeavour Hills
    and let me just shamelessly hijack your thread;
    how about a 1" master anything out there?
    now with your question if the dimentons are the same then it should work, but I was reading about needed the non ABS version.
    Clay
    Barossa!
    yeah what is different about the abs and non abs version? was having this disscussion with my brother a few hours ago
    im 90% sure the 33 is 1'' because they have the bigger brakes than the 32. but not 100%
    Endeavour Hills
    gives me a direction to start looking, thanks for the tip, sorry for the thread hi-jack
    Clay
    Barossa!
    hang on wait there i remeber reading about a 1'' b/m
    ill go thread searching
    Clay
    Barossa!
    bm44 is the r33 master
    ill go out and see if theres anymarkings on it
    (found this in andys ipra coupe build thread about pg 8 onwards)
    Clay
    Barossa!
    my master cylinder says bm44
    so how do i go about fitting this to my ke70 and ae86 brake booster? is it just a case of redrilling the holes or what?
    Clay
    Barossa!
  1. URAS JZX100
    By leigh4110 in forum Cars for Sale (Toyota Only)
    Last Post: 15th August 2011, 11:35 PM
  2. Replies: 2
    Last Post: 21st February 2011, 05:52 PM
  3. Deafkid JZX100
    By deafkid in forum Other Toyotas
    Last Post: 20th March 2010, 04:25 PM
  4. Jzx100
    By Justin Holden in forum Cars for Sale (Toyota Only)
    Last Post: 23rd June 2009, 02:19 PM
  5. master cylinder bore size
    By dr1ft-pig in forum Technical - Questions
    Last Post: 2nd September 2008, 09:43 PM
