Page 10 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 91 to 100 of 104
Thread: All about welders and welding
  1. #91
    Adan
    Oxley Park
    hmm, where u at again?
    Cause ill be driving from melbourne to shepparton on the 27th of december.
    Im sure Ill have some room in the back of the ute if i were to swing by your town
  2. #92
    Senior Member macca1590's Avatar
    Central Qld
    so i just bought cheep off a mate a weldcorp mig 160, how fucked am i? haha
    so far so good, wire feed a bit notchy/uneven feed at times but thats about it.
  3. #93
    Moderator Sam-Q's Avatar
    Endeavour Hills
    change the liner, drive wheel(s) and then have only a light tension on the wire and you will likely find that it significantly improves. Running too much wire tension from the rollers is a common thing, your meant to be able to stop the wire coming out with your fingers.
  4. #94
    Mt Macedon
    I'm not welding much at the moment and trying to keep on top of it by reading what I can. If anyone has any tips for good welding educational books, videos or websites then fire away.
    seems good, but the all the imperial units are annoying.
    As mentioned much earlier in this thread doing a TAFE course is a great idea. You can try all sorts of different welding, get advice along the way and end up with your welding certificate too. They often have evening classes too so you can fit it around the 9-5 if required.
  5. #95
    I've been keeping notes and writing stuff down as i go, so i'll put something up sometime about ideas of where to start, and what i found made the biggest differences.
    At Tafe i started with an Oxy, and that was good to get a feel for what the puddle was / should be doing and how it fallls through when you blow a hole in it etc. But for the average home person, it would be a waste to buy one unless you were serious about restoration work.
  6. #96
    Veteran drift kid's Avatar
    Glossodia
    some TIG i did lately
    and some MIG on micheal's 4 link boxes
  7. #97
    Senior Member Casey-G's Avatar
    Casey
    Nice tig work drift kid (what's ya real name?)
    Done much pipe work with TIG?
  8. #98
    Glossodia
    name's Ben and yeah a little, my skills are slowly growing, I'm progressing with the Alloy TIG quite fast at the moment, i really enjoy Alloy but the cleaning and prep are so crucial that it frustrates me lol. next time i TIG some pipe I'll shoot some pics up.
  9. #99
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    do my boot in tube???? would look so many cools (either way i dont mind)
  10. #100
    Adan
    Oxley Park
    Ok, "Ally" is short for aluminium.
    "Alloy" is a metallic mixture made from two or more elements.
    Alloy wheels and sheet aluminium are not the same material, sorry if I offend but my tafe teacher drilled us on it when I did my apprenticeship and cant handle the misuse of the word and abbreviation.
    Anyways, I havent dont much lately, but heres the last few little bits of welding I did in the garage.
  1. Tig Welders
    By willa in forum Tool Talk
    Last Post: 23rd March 2011, 08:20 AM
  2. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  3. welders flash
    Last Post: 10th August 2007, 12:41 AM
